[postgis-users] st_clusterwithin on postgis 2
Birgit Laggner
birgit.laggner at thuenen.de
Thu Sep 22 00:47:15 PDT 2016
Hi Paolo,
sorry, I did not really think it through, but now the changed and tested
example:
DO $$
DECLARE distance numeric; t_schema varchar; input_table varchar;
output_table varchar; r record; gid integer; geom geometry; c record;
c_gid integer[]; c_geom geometry[]; i record;
BEGIN
distance := 200;
t_schema := 'p_sam';
input_table := 'cluster_test_input';
output_table := 'cluster_test_output';
CREATE TEMP TABLE clustered (gid integer) ON COMMIT DROP;
EXECUTE 'SELECT gid, geom FROM
'||quote_ident(t_schema)||'.'||quote_ident(input_table) INTO r;
gid := r.gid;
geom := r.geom;
EXECUTE 'INSERT INTO clustered SELECT '||gid;
LOOP
EXECUTE 'SELECT array_agg(gid) as gid, array_agg(geom) as geom
FROM
'||quote_ident(t_schema)||'.'||quote_ident(input_table)||'
WHERE gid NOT IN (SELECT gid FROM clustered) AND
ST_DWithin($1, geom, $2)'
INTO c USING geom, distance;
c_gid := c.gid;
c_geom := c.geom || array[geom]::geometry[];
EXECUTE 'INSERT INTO clustered SELECT unnest($1)' USING c_gid;
geom := ST_ForceCollection(ST_Collect(c_geom));
EXIT WHEN c IS NULL;
END LOOP;
'||quote_ident(t_schema)||'.'||quote_ident(output_table)||' VALUES($1)'
USING geom;
LOOP
BEGIN
WHERE gid NOT IN (SELECT gid FROM clustered)' INTO r;
gid := r.gid;
geom := r.geom;
LOOP
FROM
c_gid := c.gid;
END LOOP;
VALUES ($1)' USING geom;
EXCEPTION WHEN SQLSTATE '22004' THEN EXIT;
END;
END LOOP;
END $$
Regards,
Birgit
Am 21.09.2016 um 14:53 schrieb Birgit Laggner:
> Hi Paolo,
> here an example how it could work (mind that you have to replace the
> ??). You could also recode the DO block into a function if you would
> like that better.
> DO $$
> c_gid integer[]; c_geom geometry;
> BEGIN
> distance := ??;
> t_schema := '??';
> input_table := '??';
> output_table := '??';
> gid := r.gid;
> geom := r.geom;
> ST_ForceCollection(ST_Collect(ST_Collect(geom),$2)) as geom FROM
> '||quote_ident(t_schema)||'.'||quote_ident(input_table)||' WHERE gid
> != $1 AND ST_DWithin($2, geom, $3)' INTO c USING gid, geom, distance;
> c_gid := c.gid;
> c_geom := c.geom;
> VALUES($1)' USING c_geom;
> LOOP
> BEGIN
> gid := r.gid;
> geom := r.geom;
> ST_ForceCollection(ST_Collect(ST_Collect(geom),$1)) as geom
> FROM '||quote_ident(t_schema)||'.'||quote_ident(input_table)||'
> c_gid := c.gid;
> c_geom := c.geom;
> VALUES ($1)' USING c_geom;
> END;
> END LOOP;
> END $$
> Regards,
> Birgit
> Am 21.09.2016 um 07:47 schrieb Paolo Importuni:
>> Hi all,
>> I need to run a query on my postgres/postgis (9.3/2.0) that uses
>> ST_CLUSTERWITHIN function. This function is available since postgis
>> 2.2.0 so I should do a soft upgrade on my ubuntu server. Since we
>> have a kind of customer demo in a few days and have no much time
>> left, I am not willing to change our setup right now, and I'd rather
>> do it after that meeting.
>> The question is: is there a way to aggregate geometries like
>> ST_ClusterWIthin does? Anybody can provide any working examples?
>> Thanks and regards
>> Paolo I.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160922/717099bd/attachment.html>
