[postgis-users] help with a query
Birgit Laggner birgit.laggner at thuenen.de
Tue Sep 27 01:54:09 PDT 2016
Hi Jonatan, I am glad I could help. Have success with the tweaking!
Regards, Birgit
Am 26.09.2016 um 14:24 schrieb Jonatan Malaver:
> Hi Birgit, thank you so much!! your code put me on the right track.
> I'm still tweaking it a bit since your code assumes only 1 line is
> attached to the endpoint. However, the endpoint of one line could
> break into 2 new starpoints.
> thanks,
> jon
> On Tue, Sep 20, 2016 at 5:38 AM Birgit Laggner
> <birgit.laggner at thuenen.de <mailto:birgit.laggner at thuenen.de>> wrote:
>     Hi Jonatan,
>     based on the anonymous code block Leknín came up with, I tried to
>     adapt it to your problem:
>     DO $$
>     DECLARE c_line record; c_gid integer; c_geom geometry; line
>     record; gid integer; geom geometry; i integer; n integer;
>     BEGIN
>     EXECUTE 'SELECT count(*) FROM electric_line' INTO n;
>     --initialize start
>     EXECUTE 'SELECT gid, geom FROM electric_line WHERE gid = 3312'
>     INTO c_line;
>     c_gid := c_line.gid;
>     c_geom := c_line.geom;
>     i := 1;
>     -- loop through lines following the flow direction
>     LOOP
>                  WHERE
>     ST_DWithin(ST_EndPoint($1,ST_StartPoint(geom),0.01) OR
>     ST_DWithin(ST_EndPoint($1),ST_EndPoint(geom),0.01)' INTO line
>     USING c_geom;
>         gid := line.gid;
>         geom := line.geom;
>         --compare end point parent line with start point child line
>     and reverse line if necessary
>             IF NOT ST_DWithin(ST_EndPoint(c_geom),
>     ST_StartPoint(geom),0.01) THEN
>             EXECUTE
>                     'UPDATE electric_line SET geom = ST_Reverse(geom)
>     WHERE gid = '||line.gid;
>             END IF;
>         --take child line as parent line for next loop
>             c_gid := gid;
>             c_geom := geom;
>             i := i + 1;
>         EXIT WHEN i = n;
>     END LOOP;
>     END $$;
>     Basically, you would start with your starting point for the flow.
>     Then you search for the next matching line and check if the
>     direction is ok. Otherwise you reverse the line. Then you go into
>     your next search loop and so on. The loop should exit when all
>     lines have been through the loop. I couldn't test the code but
>     hope you get the idea at least.
>     Regards,
>     Birgit
>     Am 14.09.2016 um 17:13 schrieb Jonatan Malaver:
>>     Hello again, I do not have parent line id. All I have is a
>>     starting point from where the direction should reference.
>>     On Wed, Sep 14, 2016 at 9:09 AM Leknín Řepánek
>>     <godzilalalala at gmail.com <mailto:godzilalalala at gmail.com>> wrote:
>>         On Wed, Sep 14, 2016 at 12:09:23PM +0000, Jonatan Malaver wrote:
>>         > the reason being is that I do a network analysis by running
>>         the following
>>         > function:
>>         > WITH RECURSIVE flow(gid, geom) AS (
>>         >     SELECT e.gid, e.geom FROM electric_line e, transformers
>>         t WHERE ST_Distance
>>         > (t.geom,ST_StartPoint(e.geom)) <= 0.01 AND t.gid=$1
>>         >   UNION ALL
>>         >     SELECT n.gid, n.geom
>>         >     FROM electric_line n, flow f
>>         >     WHERE
>>         ST_Distance(ST_EndPoint(f.geom),ST_StartPoint(n.geom)) <= 0.01
>>         > The problem I have is that some of the lines direction are
>>         in reversed. I'm
>>         > trying to correct them with referenced to the first line.
>>         Otherwise, I will end
>>         > up changing hundreds of lines manually.
>>         Manually? No. There are many of possible ways how do this by
>>         query. For
>>         example if you have in every line id of "parent line" you can use
>>         anonymous block of code by something like this.
>>         DO $$
>>         DECLARE line record;
>>         BEGIN
>>         FOR line in SELECT lines from lines ORDER BY id LOOP
>>                 IF NOT ST_Equal(ST_startpoint(line.geom) , (SELECT
>>                 ST_EndPoint(geom) FROM lines WHERE id =
>>         line.parent_line_id))
>>                 THEN
>>                         UPDATE lines SET geom = ST_Reverse(geom)
>>         WHERE id =
>>         line.id <http://line.id>;
>>         END LOOP;
>>         END
>>         > On Tue, Sep 13, 2016 at 11:12 AM James Keener
>>         <jim at jimkeener.com <mailto:jim at jimkeener.com>> wrote:
>>         >     Depends on what you mean by direction. If you want to
>>         grab the start and
>>         >     end points (st_startpoint and st_endpoint) and check
>>         their x and y (st_x
>>         >     and st_y) for some condition (both less at the end?)
>>         Then update the record
>>         >     with the value of st_reverse.
>>         >     I guess my other question is why it matters.
>>         >     Jim
>>         >     On September 13, 2016 8:31:07 AM EDT, Jonatan Malaver <
>>         > jon.malaver at shrewsburyma.gov
>>         <mailto:jon.malaver at shrewsburyma.gov>> wrote:
>>         >         Hello,
>>         >            I'm trying to come up with a query that would
>>         check the direction of
>>         >         a line. If the end point is not the start point of
>>         the next line to
>>         >         update the line by reversing that line. Can anyone
>>         give me pointers on
>>         >         how to do it?
>>         >         Thanks,
>>         >         Jon
>>         >         postgis-users mailing list
>>         > postgis-users at lists.osgeo.org
>>         <mailto:postgis-users at lists.osgeo.org>
>>         > http://lists.osgeo.org/mailman/listinfo/postgis-users
>>         >     Sent from my Android device with K-9 Mail. Please
>>         excuse my brevity.
>>         > Thanks,
>>         > Jonatan Malaver
>>         > Assistant Engineer of Electrical and Cable Operations
>>         > Shrewsbury Electric & Cable Operations
>>         > 100 Maple Avenue
>>         > Shrewsbury, MA 01545
>>         > Office: (508) 841-8610
>>         > Fax: (508) 842-9267
>>         > _______________________________________________
>>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20160927/eb79112a/attachment.html>
