[postgis-users] st_distance meter/degree
franco base frenk.calza at gmail.com
Thu Apr 13 04:26:20 PDT 2017
Yes thanks a lot I understand.
I did't see it first to write the question to the list.
2017-04-13 13:24 GMT+02:00 Olivier Leprêtre <o.lepretre at gmail.com>:
> *De :* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *De
> la part de* franco base
> *Envoyé :* jeudi 13 avril 2017 13:08
> *À :* PostGIS Users Discussion
> *Objet :* Re: [postgis-users] st_distance meter/degree
> Sorry.
> I don't see the 10-5at the end
> very sorry
> 2017-04-13 13:05 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt>:
> Hi Franco,
> I did not understood your question.
> Postgis calculates the distance/area according to the CRS unit. It the
> CRS unit is degrees, the results is in degrees. If the CRS unit is
> meter, the result is in meter.
> For example, if you transform the geometry, like:
> SELECT ST_Distance(ST_Transform(geometry, 25829)) ...
> the result will be in meter.
> Regards,
> Jorge
> Às 11:54 de 13-04-2017, franco base escreveu:
> > Thanks Jorge but it isn't the matter.
> > I'd know why postgis have a different way to calculate the distance
> > with the same sql query.
> > 2017-04-13 12:37 GMT+02:00 Jorge Gustavo Rocha <jgr at di.uminho.pt
> > <mailto:jgr at di.uminho.pt>>:
> >     Hi Franco,
> >     You can use the usual control statements IF THEN ELSE [1] to make it
> >     exactly like you want.
> >     [1]
> >     https://www.postgresql.org/docs/current/static/plpgsql-
> control-structures.html
> >     <https://www.postgresql.org/docs/current/static/plpgsql-
> control-structures.html>
> >     Regards,
> >     Jorge
> >     Às 10:57 de 13-04-2017, franco base escreveu:
> >     > Hi all.
> >     > Is it possible that st_distance between point return meter
> distance if
> >     > point are very close and degrees otherwise?
> >     > SELECT ST_distance ( ST_SetSRID
> >     > (ST_MakePoint(45.4553804010375,9.11292550791171) ,4326),
> ST_SetSRID
> >     > (ST_MakePoint(45.4553855607023,9.11291318106981) ,4326))
> >     > return 1.3 ( meter distance)
> ST_SetSRID
> >     > (ST_MakePoint(45.4560699405679,9.1164832309759) ,4326))
> >     > return 0.003 (degrees distance)
> >     > Thanks
> >     > fb
> >     > _______________________________________________
> >     > postgis-users mailing list
> >     > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.
> osgeo.org>
> >     > https://lists.osgeo.org/mailman/listinfo/postgis-users
> >     <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> >     J. Gustavo
> >     Jorge Gustavo Rocha
> >     Departamento de Informática
> >     Universidade do Minho
> >     4710-057 Braga
> >     Tel: +351 253604480 <tel:%2B351%20253604480 <%2B351%20253604480>>
> >     Fax: +351 253604471 <tel:%2B351%20253604471 <%2B351%20253604471>>
> >     Móvel: +351 910333888 <tel:%2B351%20910333888 <%2B351%20910333888>>
> >     skype: nabocudnosor
> >     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> J. Gustavo
> Jorge Gustavo Rocha
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> skype: nabocudnosor
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> Garanti
> sans virus. www.avast.com
> <#m_8297045088223226183_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170413/33f34e14/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170413/33f34e14/attachment.png>
