[postgis-users] <-> operator does not return true distance
Jakob Miksch
Jakob.Miksch at nina.no
Tue Aug 1 05:49:17 PDT 2017
Hello Regina,
Thanks for your helpful response. Indeed there was a problem with the update of PostGIS.
We fixed it and now everything works like it should.
Kind regards,
Jakob
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Regina Obe
Sent: torsdag 13. juli 2017 22.51
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] <-> operator does not return true distance
Jakob,
Did you upgrade your install from an older version say 9.4.
I think if you did a pg_upgrade, and didn't do a ALTER EXTENSION postgis... after upgrade, this would explain your issue since the operators would not get upgraded.
On my PostGIS 2.3.2, 9.6 behavior is as expected. Unfortunately I don't have 2.2.2 lying around at moment.
Also there was an ordering bug I think in 2.2 early version that may have caused this. If that is your issue, then output of <-> would be real even though ordering is wrong.
Try this query:
SELECT id,
ST_Distance(my_point.geom,
my_polygons.geom) AS real_distance,
ST_Centroid(my_polygons.geom)) AS centroid_distance, my_point.geom <-> my_polygons.geom
FROM (
SELECT 'blue' AS id, ST_Polygon(ST_GeomFromText('LINESTRING(0 3, 2 3, 2 4, 0 4 ,0 3)'),4326) AS geom
UNION
SELECT 'green' AS id, ST_Polygon(ST_GeomFromText('LINESTRING(2 0, 8 0 , 8 2, 2 2 ,2 0)'),4326) AS geom
) AS my_polygons,
SELECT ST_SetSRID(ST_Point(1, 1),4326) AS geom
) AS my_point
ORDER BY my_point.geom <-> my_polygons.geom
-- output should be --
id | real_distance | centroid_distance | ?column?
green | 1 | 4 | 1
blue | 2 | 2.5 | 2
(2 rows)
Hope that helps,
Regina
http://postgis.us
http://www.paragoncorporation.com
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jakob Miksch
Sent: Thursday, July 13, 2017 4:27 AM
To: postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-users] <-> operator does not return true distance
(I asked a similar question here https://gis.stackexchange.com/questions/247034/postgis-operator-does-not-return-true-distance )
I used the <-> operator with PostGIS 2.2.2 and PostgreSQL 9.5.7 .
According to the docs (http://postgis.net/docs/manual-2.2/geometry_distance_knn.html) the <-> operator should order by "true KNN distance" and *not* by "centroid distance".
However it does not work for me. See the minimal example below:
( illustration: https://i.stack.imgur.com/QZA6D.png )
SELECT id,
FROM (
UNION
) AS my_polygons,
) AS my_point
--- obtained Result:
| blue | 2 | 2.5 |
| green | 1 | 4 |
(I expected the rows to be in the opposite order)
Apparently the <-> operator orders by the centroid_distance and not by the real_distance, even though the docs say: "[...] for PostgreSQL 9.5+, does true KNN distance search giving true distance between geometries [...]"
I tried the same example on 2.3.2 and PostgreSQL 9.5.7 and I get the expected result (which orders by "real_distance").
So, for me it seems that ordering by "real_distance" with the <-> operator does not work with PostGIS 2.2.2 - but this is *not* written in the docs.
Can you reproduce this behaviour? Or did I understand/make something wrong here?
Thanks and best regards,
Jakob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170801/3b4278a0/attachment.html>
