[postgis-users] duplicated nodes
Olivier Leprêtre
o.lepretre at gmail.com
Wed Aug 2 12:28:18 PDT 2017
I have a point layer that contains several superposed nodes two, three times
or more. I would like to display each group list and the number of item in
each. I found this query which works but returns some false positive
select case when lag(o.geom) OVER (PARTITION BY o.geom) = o.geom then ''
else 'x ' || o.nbre::text end,d.code from
(select geom,count(*) as nbre from nodes group by geom having count(*) >1)
as o,
lateral (select * from nodes) as d where st_within(o.geom,d.geom)
I understand that false positives (yellow beneath) comes from group by
geom which use a bounding box and catch close but not duplicated points.
I tried other solutions which all get too complicated with several join of
join. I would appreciate if someone has an idea on the top of his/her head
Thanks
Olivier
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170802/34d2e924/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170802/34d2e924/attachment.jpg>
