[postgis-users] strange behaviour in PostGIS strictly below operator?
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Fri Aug 11 07:03:42 PDT 2017
Hi!
These are bbox operations, and IIRC they operate on float (32bit) bbox of
geometry. I think conversion of point to bbox adds some epsilon around a
point.
пт, 11 авг. 2017 г. в 16:57, Thijs van den Berg <thijs at sitmo.com>:
> Hi All,
> I'm getting some strange results that I can’t explain. Maybe some of you
> know whats going on?
> I want to use PostGIS for spatial queries on scientific data (2d point
> sets). In the following query I want to select points to the left of some
> other point but it looks like there is some rounding going on? AFAIK the
> coordinates are stored as 64bit doubles and so this should be no problem?
> This query gives TRUE as expected:
> SELECT ST_PointFromText('POINT(88605254 0)') <<
> ST_PointFromText('POINT(88605300 0)’);
> This query gives FALSE,the only difference is two leading 2’s in the X
> coordinate.
> SELECT ST_PointFromText('POINT(2288605254 0)') <<
> ST_PointFromText('POINT(2288605300 0)');
> Below is my version info:
> SELECT PostGIS_full_version();
> POSTGIS="2.3.2 r15302" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.3, 15
> August 2016" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.9.4"
> LIBJSON="0.12.1” RASTER
> Kind regards,
> Thijs
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170811/1c3cfbe2/attachment.html>
