[postgis-users] Create a new data type for PostGIS in C
Regina Obe lr at pcorp.us
Thu Aug 17 19:42:24 PDT 2017
Fabiana,
This question is better asked on postgis-developers list.  Please join that
list if you are not subscribed already.
https://lists.osgeo.org/mailman/listinfo/postgis-devel
I've cc'd PostGIS development to start things off.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Fabiana Zioti
Sent: Thursday, August 17, 2017 1:37 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Create a new data type for PostGIS in C
Hello,
I developed some basic extensions for PostgreSQL to study. The extensions
contained input and output functions, operators, index (GiST), among others.
Now I would like to create a new data type for PostGIS, but I have some
difficulties. Here's what I've done so far:
struct trajectory_elem
  int32 id;
  Timestamp time_obj;
  GSERIALIZED *geom_elem;       /* Geometry Object */
#define DatumGetTrajectoryElem(X)      ((struct trajectory_elem*)
PG_DETOAST_DATUM(X))
#define PG_GETARG_TRAJECTELEM_TYPE_P(n)
DatumGetTrajectoryElem(PG_GETARG_DATUM(n))
#define PG_RETURN_TRAJECTELEM_TYPE_P(x)  PG_RETURN_POINTER(x)
PG_FUNCTION_INFO_V1(trajectory_elem);
Datum
trajectory_elem(PG_FUNCTION_ARGS)
  int32 id = PG_GETARG_INT32(0);
  Timestamp timestamp = PG_GETARG_TIMESTAMP(1);
  GSERIALIZED *geom = (GSERIALIZED*)PG_DETOAST_DATUM(PG_GETARG_DATUM(2));
  LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
  struct trajectory_elem *trje = (struct trajectory_elem *)
palloc(sizeof(struct trajectory_elem));
  size_t size;
  /*elog(NOTICE, "trajectory_elem called");*/
  if (lwgeom_is_empty(lwgeom) || lwgeom->type != POINTTYPE)
    elog(NOTICE, "trajectory_elem is NULL, or type is not correct");
  PG_RETURN_NULL();
  trje->id = id;
  trje->time_obj = timestamp;
  trje->geom_elem = gserialized_from_lwgeom(lwgeom, &size);
  elog(NOTICE, "trajectory_elem finish");
  /* Then call free_if_copy on the *varlena* structures you originally get
as arguments */
  lwgeom_free(lwgeom);
  PG_FREE_IF_COPY(geom, 0);
  PG_RETURN_TRAJECTELEM_TYPE_P(trje);
I also imprinted the output function using lwgeom_to_hexwkb(lwgeom,
WKB_EXTENDED, &size);
But in PG_RETURN the connection is closed.
It is wrong the way I'm programming the UDT for PostGIS?
Thanks in advance !! (and Sorry for the english)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170817/2e2a8dbb/attachment.html>
