[postgis-users] ST_Intersects(BOOM!)
Regina Obe
lr at pcorp.us
Mon Aug 28 20:38:55 PDT 2017
Aaron,
This works fine for me.
I'm also assuming you are using geometry and not geography so the code snippet you pointed at shouldn't be relevant.
In case you are though I tested both and they work fine for me.
What does your
SELECT postgis_full_version();
Return? Mine returns:
POSTGIS="2.4.0dev r15600" GEOS="3.7.0dev-CAPI-1.11.0 8fe2ce6" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.2.1, released 2017/06/23" LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
But the 2.4.0 part shouldn't matter, if you are running a lower Proj, that might matter.
Here is how I tested -- just to verify we are testing the same thing
I got to test out my new http extension compile - https://github.com/pramsey/pgsql-http
CREATE EXTENSION http;
CREATE TABLE whosonfirst(id serial, geom geometry);
--SELECT http_set_curlopt('CURLOPT_CAINFO', 'C:/ssl/certs/ca-bundle.crt');
INSERT INTO whosonfirst(geom)
SELECT ST_GeomFromGeoJSON(h.content::jsonb->>'geometry')
FROM http_get('https://whosonfirst.mapzen.com/data/136/253/057/136253057.geojson') AS h;
-- this works
SELECT id FROM whosonfirst WHERE ST_Intersects(geom::geography, ST_GeomFromGeoJSON('{"type": "Point",
"coordinates": [145.748209, 15.193315]}')::geography);
Returns 1 as expected.
This also works:
SELECT id FROM whosonfirst WHERE ST_Intersects(geom::geometry, ST_GeomFromGeoJSON('{"type": "Point",
"coordinates": [145.748209, 15.193315]}')::geometry);
Returns 1
SELECT ST_NPoints(geom) from whosonfirst;
Returns:
36822
Hope that helps,
Regina
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Aaron Cope
Sent: Monday, August 28, 2017 6:24 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] ST_Intersects(BOOM!)
Apologies if this has been answered elsewhere already. If it has I've not been able to find it.
We are using PGIS to do point-in-poly lookups and having trouble involving certain very large records.
SELECT version();
version
PostgreSQL 9.6.4 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
(1 row)
Specifically:
https://whosonfirst.mapzen.com/spelunker/id/136253057/
Whose MBR is:
-179.143503384, -14.532891534, 179.780935092, 71.412502346
This is where it starts to get confusing for me. PGIS indicates that both the geometry itself and the point we are trying to intersect with are valid:
SELECT ST_IsValid(geom::geometry) FROM whosonfirst WHERE id=136253057; st_isvalid
t
(1 row)
SELECT ST_IsValid(ST_GeomFromGeoJSON('{"type": "Point", "coordinates":
st_isvalid
t
(1 row)
However, when try to intersect against the former I trigger the "BOOM!
Could not generate outside point" error:
SELECT id, parent_id, placetype_id, meta FROM whosonfirst WHERE ST_Intersects(geom, ST_GeomFromGeoJSON('{"type": "Point",
"coordinates": [145.748209, 15.193315]}'));
ERROR: BOOM! Could not generate outside point!
https://github.com/postgis/postgis/blob/cc3437595e88eac7f20b0f3b780a3816cdc912c9/liblwgeom/lwgeodetic.c#L1536-L1537
We've also been able to reproduce the problem with this record which has a similarly large MBR:
https://whosonfirst.mapzen.com/spelunker/id/136253037/
https://whosonfirst.mapzen.com/data/136/253/037/136253037.geojson
Am I missing something obvious or is there something else at work here?
Thanks,
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
