[postgis-users] Bad plan without && operator
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Dec 6 09:57:37 PST 2017
I have 2 tables, indexed and analyzed.
One big (batiment) with 45M records, one small (tmp.tp1), with 83k records
(UNLOGGED table)
When performing a spatial join, the planner chooses the smallest table for
seq scan only if I add a && condition with st_intersects:
EXPLAIN SELECT p.id, b.id
FROM tmp.tp1 p join ref.batiment b on st_intersects(b.geom, p.geom);
QUERY PLAN
Nested Loop (cost=0.15..21819347.50 rows=50019 width=35)
-> Seq Scan on batiment b (cost=0.00..2238826.04 rows=45794904
width=193)
-> Index Scan using tp1_geom_gist on tp1 p (cost=0.15..0.42 rows=1
width=276)
Index Cond: (b.geom && geom)
Filter: _st_intersects(b.geom, geom)
vs
FROM tmp.tp1 p join ref.batiment b on p.geom && b.geom and
QUERY PLAN
Nested Loop (cost=0.42..118443.25 rows=1 width=35)
-> Seq Scan on tp1 p (cost=0.00..842.75 rows=13675 width=276)
-> Index Scan using batiment_geom_gist on batiment b (cost=0.42..8.59
rows=1 width=193)
Index Cond: ((p.geom && geom) AND (geom && p.geom))
Filter: _st_intersects(geom, p.geom)
PG:
PostgreSQL 9.6.6 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit
Postgis:
POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.2, 08
September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.3.2 r15302" need
upgrade) RASTER
Thanks for any hint.
Nicolas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171206/1ce58582/attachment.html>
