[postgis-users] Bad plan without && operator
Paul Ramsey
pramsey at cleverelephant.ca
Wed Dec 6 13:36:49 PST 2017
If you change the small table into a normal table (not unlogged) does
the problem go away? Could be an interesting side effect of
"unlogged"?
On Wed, Dec 6, 2017 at 1:14 PM, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Yes, tables are analyzed.
> I tried reverting argument, same plan generated:
> EXPLAIN SELECT p.id, b.id
> FROM tmp.tp1 p join ref.batiment b on st_intersects(p.geom, b.geom);
> QUERY PLAN
> Nested Loop (cost=0.15..21819347.50 rows=50019 width=35)
> -> Seq Scan on batiment b (cost=0.00..2238826.04 rows=45794904
> width=193)
> -> Index Scan using tp1_geom_gist on tp1 p (cost=0.15..0.42 rows=1
> width=276)
> Index Cond: (geom && b.geom)
> Filter: _st_intersects(geom, b.geom)
> Nico
> On 6 December 2017 at 19:14, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Just invert the arguments in your call to ST_Intersects().
>> I don't think we have any way to tell the planner anything about which
>> side of the condition should drive the nested loop join. And yet it
>> seems to get the "right" one most of the time. I assume you've already
>> run 'ANALYZE' and the stats are all up-to-date.
>> P.
>> On Wed, Dec 6, 2017 at 9:57 AM, Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>> > Hi,
>> > I have 2 tables, indexed and analyzed.
>> > One big (batiment) with 45M records, one small (tmp.tp1), with 83k
>> > records
>> > (UNLOGGED table)
>> > When performing a spatial join, the planner chooses the smallest table
>> > for
>> > seq scan only if I add a && condition with st_intersects:
>> > FROM tmp.tp1 p join ref.batiment b on st_intersects(b.geom, p.geom);
>> > QUERY PLAN
>> > width=193)
>> > width=276)
>> > Index Cond: (b.geom && geom)
>> > Filter: _st_intersects(b.geom, geom)
>> > vs
>> > FROM tmp.tp1 p join ref.batiment b on p.geom && b.geom and
>> > QUERY PLAN
>> > Nested Loop (cost=0.42..118443.25 rows=1 width=35)
>> > -> Seq Scan on tp1 p (cost=0.00..842.75 rows=13675 width=276)
>> > -> Index Scan using batiment_geom_gist on batiment b
>> > (cost=0.42..8.59
>> > rows=1 width=193)
>> > Index Cond: ((p.geom && geom) AND (geom && p.geom))
>> > Filter: _st_intersects(geom, p.geom)
>> > PG:
>> > PostgreSQL 9.6.6 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
>> > 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit
>> > Postgis:
>> > POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.2,
>> > 08
>> > September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
>> > LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.3.2 r15302" need
>> > upgrade)
>> > RASTER
>> > Thanks for any hint.
>> > Nicolas
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
