[postgis-users] Bad plan without && operator
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Dec 7 00:37:56 PST 2017
Hi Nicolas,
I've seen that behavior for tables that have same, rather sparse but
worldwide coverage for points and polygons.
In my case it was due to statistic histogram having not enough resolution
to properly estimate selectivity.
When you add more && to request, you basically replace selectivity by
selectivity^2 in planner.
Another way to change this may be
ALTER TABLE tmp.tp1 SET STATISTICS 10000;
ALTER TABLE ref.batimet SET STATISTICS 10000;
ANALYZE tmp.tp1;
ANALYZE ref.batimet;
By default table is estimated by histogram of 100 cells, basically grid
10x10. 10000 changes it to 100x100, allowing
чт, 7 дек. 2017 г. в 11:24, Nicolas Ribot <nicolas.ribot at gmail.com>:
> Same with a logged table.
> It seems the && condition have to be duplicated for the right plan to be
> chosen:
> EXPLAIN SELECT p.id, b.id
> FROM tmp.tp1 p join ref.batiment b
> on b.geom && p.geom and p.geom && b.geom and _st_intersects(b.geom,
> p.geom);
> On 6 December 2017 at 22:36, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> If you change the small table into a normal table (not unlogged) does
>> the problem go away? Could be an interesting side effect of
>> "unlogged"?
>> On Wed, Dec 6, 2017 at 1:14 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>> > Yes, tables are analyzed.
>> > I tried reverting argument, same plan generated:
>> > FROM tmp.tp1 p join ref.batiment b on st_intersects(p.geom, b.geom);
>> > QUERY PLAN
>> > Nested Loop (cost=0.15..21819347.50 rows=50019 width=35)
>> > -> Seq Scan on batiment b (cost=0.00..2238826.04 rows=45794904
>> > width=193)
>> > -> Index Scan using tp1_geom_gist on tp1 p (cost=0.15..0.42 rows=1
>> > width=276)
>> > Index Cond: (geom && b.geom)
>> > Filter: _st_intersects(geom, b.geom)
>> > Nico
>> > On 6 December 2017 at 19:14, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> >> Just invert the arguments in your call to ST_Intersects().
>> >> I don't think we have any way to tell the planner anything about which
>> >> side of the condition should drive the nested loop join. And yet it
>> >> seems to get the "right" one most of the time. I assume you've already
>> >> run 'ANALYZE' and the stats are all up-to-date.
>> >> P.
>> >> On Wed, Dec 6, 2017 at 9:57 AM, Nicolas Ribot <nicolas.ribot at gmail.com
>> >> wrote:
>> >> > Hi,
>> >> > I have 2 tables, indexed and analyzed.
>> >> > One big (batiment) with 45M records, one small (tmp.tp1), with 83k
>> >> > records
>> >> > (UNLOGGED table)
>> >> > When performing a spatial join, the planner chooses the smallest
>> table
>> >> > for
>> >> > seq scan only if I add a && condition with st_intersects:
>> >> > FROM tmp.tp1 p join ref.batiment b on st_intersects(b.geom, p.geom);
>> >> > QUERY PLAN
>> >> > width=193)
>> rows=1
>> >> > width=276)
>> >> > Index Cond: (b.geom && geom)
>> >> > Filter: _st_intersects(b.geom, geom)
>> >> > vs
>> >> > FROM tmp.tp1 p join ref.batiment b on p.geom && b.geom and
>> >> > QUERY PLAN
>> >> > Nested Loop (cost=0.42..118443.25 rows=1 width=35)
>> >> > -> Seq Scan on tp1 p (cost=0.00..842.75 rows=13675 width=276)
>> >> > -> Index Scan using batiment_geom_gist on batiment b
>> >> > (cost=0.42..8.59
>> >> > rows=1 width=193)
>> >> > Index Cond: ((p.geom && geom) AND (geom && p.geom))
>> >> > Filter: _st_intersects(geom, p.geom)
>> >> > PG:
>> >> > PostgreSQL 9.6.6 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
>> >> > 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit
>> >> > Postgis:
>> >> > POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel.
>> 4.9.2,
>> >> > 08
>> >> > September 2015" GDAL="GDAL 1.11.3, released 2015/09/16"
>> LIBXML="2.9.3"
>> >> > LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.3.2 r15302" need
>> >> > upgrade)
>> >> > RASTER
>> >> > Thanks for any hint.
>> >> > Nicolas
>> >> > _______________________________________________
>> >> > postgis-users mailing list
>> >> > postgis-users at lists.osgeo.org
>> >> > https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171207/cbdd291b/attachment.html>
