[postgis-users] Given up
Tijan49
tijan49 at yahoo.fr
Mon Dec 11 08:55:34 PST 2017
Some time ago I installed PostgreSQL with the DBEntreprise installer,
but it was coming with the PgAdmin 4,witch I really didn't appreciate
(mostly because it runs really slowly in comparison with PgAdmin3 on my
machine ...).
For that reason I came back to PostgreSQL 9.6.
Do you know If it's now possible to have PostgreSQL 10 installed with
PgAdmin 3 (or if PgAdmin 4 has dealt with his problems of slowness, wich
many people have noticed) ?
Thanks,
Jean
Le 11/12/2017 à 14:40, Anthony DeBarros a écrit :
> Regina (or anyone),
> I had posted a couple weeks back about not being able to find a
> version of the Shapefile Loader GUI that works under macOS High
> Sierra. The one I recently downloaded from Boundless doesn’t work. Any
> ideas on alternates?
> Thanks,
> Anthony
> On December 11, 2017 at 8:23:31 AM, Regina Obe (lr at pcorp.us
> <mailto:lr at pcorp.us>) wrote:
>> Darrel,
>> There was an issue with when PostgreSQL 10 came out that the stack
>> builder did not show the PostGIS spatial extension I had uploaded.
>> This was fixed in PostgreSQL 10.1 so perhaps you went to it pre-10.1.
>> Regarding not creating spatial db, that is odd. There is a checkbox
>> to create one, but I do have it unchecked by default, cause it's
>> better for people to just use CREATE EXTENSION on whatever database
>> they want. I keep that feature there just so I can test when I
>> deploy to make sure all extensions can be created.
>> As noted by Bo below, BigSQL packages PostGIS too and that one IS NOT
>> VIA STACKBUILDER. STACKBUILDER is for EDB installs.
>> Use pgc commandline or pgDevOps for BigSQL.
>> However, the EDB windows and BigSQL Windows binaries are compatible
>> (both compiled with mingw64), so if you ever need anything you can't
>> find in BigSQL (pgRouting and SFCGAL come to mind)
>> You can use the zip binaries on this page –
>> https://postgis.net/windows_downloads/
>> Thanks,
>> Regina
>> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
>> <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Bo
>> Victor Thomsen
>> *Sent:* Monday, December 11, 2017 4:14 AM
>> *To:* postgis-users at lists.osgeo.org
>> <mailto:postgis-users at lists.osgeo.org>
>> *Subject:* Re: [postgis-users] Given up
>> Hi Darrel -
>> As you already have found an alternative installation, this mail is
>> just a heads-up for future users of the BigSQL installation of
>> PostgreSQL:
>> ·The BigSQL administrative interface is based on some kind of local
>> http-server software, which serves a JavaScript based program for
>> installing/upgrading PostgreSQL and extensions (localhost:8051 IIRC)
>> ·This works very nicely (some times). But depending on your choice of
>> antivirus - it can be a *royal* pain, because *your* antivirus
>> software a lot of the time will stop *you* from using the interface.
>> ·However, BigSQL has an alternative installation method: the *pgc*
>> command line interface.
>> ·You can do the following:
>> oStart a DOS box with administrative rights (Right-click the dox-box
>> icon, choose "Run as Administrator")
>> oIn the dos box, navigate to the installation directory of BigSQL,
>> usually c:\PostgreSQL or c:\BigSQL
>> otype "pgc" . This will give you a list of supported command for pgc.
>> oExample - Install the PostGIS 2.4 extension for PostgreSQL: type
>> "*pgc install postgis24-pg10*"
>> oGive it a minute to download and install and then: Voila! you have
>> the PostGIS extension for PostgreSQL installed and ready for use.
>> Regards
>> Bo Victor Thomsen
>> LIFA A/S, Denmark
>> Den 10-12-2017 kl. 20:29 skrev Darrel Maddy:
>> Dear all,
>> This is probably not the best time for me to be writing this but
>> I think it is sometimes useful to report negative outcomes.
>> I have a new laptop running windows 10. I have not installed
>> postgresql or postgis for some time so I decided to use the
>> binaries. Using the BIGSQL download proved to be a nightmare.
>> Postgresql 10 installs without issue but with no stackbuilder
>> option (it does not appear anywhere in the menus nor in the
>> directories) I attempted to try and install the postgis
>> binaries. Needless to say that failed with repeated errors for
>> files it could not find. I have spent a few hours trying to
>> convince this that the files are there but now I have given up.
>> To add insult to injury the postgis uninstall did not work and
>> the postgresql uninstall failed to remove most of its components.
>> God knows what mess it has made of any registry entries (assuming
>> it does that). I tried 9.6 but stackbuilder did not appear there
>> either so I have lost whatever patience I may have started out
>> with. I realise the install instructions do not refer to the
>> latest versions but I reluctantly admit failure. May be I just
>> cannot follow instructions?
>> Perhaps as I get older I forget previous experience but I do not
>> remember it being such a mess previously. Maybe I will try again
>> in a month or two – is the situation likely to improve?
>> Sorry but I needed to get this off my chest and the criticism is
>> NOT aimed at anyone in particular.
>> Darrel
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171211/250abab5/attachment.html>
