[postgis-users] HELP - Geometrycollection - CREATE VIEW - Empty Table
Tõnis Kärdi
Tonis.Kardi at kemit.ee
Thu Dec 14 07:52:37 PST 2017
That's good you got that resolved :)
Cheerio,
Tõnis
________________________________________
Saatja: postgis-users <postgis-users-bounces at lists.osgeo.org> ofoerster at posteo.de <ofoerster at posteo.de> nimel
Saadetud: 14. detsember 2017 17:24
Adressaat: PostGIS Users Discussion
Teema: Re: [postgis-users] HELP - Geometrycollection - CREATE VIEW - Empty Table
Hi Tõnis,
thanks for the quick answer. A friend solved the problem with this
function:
CREATE VIEW parcel_polygons AS (
SELECT
polys_and_points.*
FROM
(SELECT
row_number() OVER(ORDER BY inspire_local DESC) AS OID
, inspire_local
, inspire_namespace
, label
, nationalcadref
, areavalue
, validfrom
, beginlifespanversion
, zoning
, (ST_dump(geom)).geom
FROM cp_parcel_postgis) as polys_and_points
WHERE
st_geometrytype(polys_and_points.geom) = 'ST_Polygon'
best regards,
Oli
Am 14.12.2017 14:11 schrieb Tõnis Kärdi:
> Hi Oli,
> Have you checked the distinct values you are getting for geometrytype?
> Something in the lines of
> select distinct geometrytype(geom) from cp_parcel_postgis;
> Is 'GEOMETRYCOLLECTION(POLYGON)' listed there?
> I think the geometrytype of a geometrycollection is simply
> 'GEOMETRYCOLLECTION'. So most probably the filter you are using
> filters everything out.
> All the best,
> Tõnis
> Saadetud: 14. detsember 2017 14:30
> Adressaat: postgis-users at lists.osgeo.org
> Teema: [postgis-users] HELP - Geometrycollection - CREATE VIEW - Empty
> Table
> Hello PostGIS Community,
> I have a Problem. I have a table with a geometry collection (polygon
> and
> point).
> QGIS can not read the geometry collection, so I want to create a view
> for the polygon type and the point type. My SQL function for the
> polygon
> type looks like this:
> SELECT
> , inspire_local
> , inspire_namespace
> , label
> , nationalcadref
> , areavalue
> , validfrom
> , zoning
> , geom::geometry(Polygon, 25833)
> WHERE GeometryType(geom) = 'GEOMETRYCOLLECTION(POLYGON)'
> I do not get any errors and the view is created. Unfortunately, the
> view
> is empty.
> What am I doing wrong?
> Thanks for any help,
> Oli
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
