[postgis-users] Intersection of three polygons
Saranya Kuniyil
saranyak578 at gmail.com
Tue Feb 21 01:51:40 PST 2017
Hai,
yes. I am interested to retrieve all polygons which intersects any one
among three categories..
In the above example,
1)POLYGON((0 0,0 1,1 1,1 0,0 0)) filename as part1
POLYGON((0 0,0 2,2 2,2 0,0 0)) filename as part2
POLYGON((0 0,0 3,3 3,3 0,0 0)) filename as part3
>From these polygons I need to get Intersecting polygon as POLYGON((0 0,0
1,1 1,1 0,0 0)),
2)POLYGON((0 0,0 3,3 3,3 0,0 0)) filename as part1
2,2 2,2 0,0 0)).
3)POLYGON((0 0,0 3,3 3,3 0,0 0)) filename as part1
POLYGON((0 0,0 5,5 5,5 0,0 0)) filename as part2
POLYGON((0 0,0 4,4 4,4 0,0 0)) filename as part3
3,3 3,3 0,0 0)).
Other combinations also returns same answer.
Thanks
On Tue, Feb 21, 2017 at 4:57 AM, Giuseppe Broccolo <
giuseppe.broccolo at 2ndquadrant.it> wrote:
> Hi Saranya,
> 2017-02-20 5:57 GMT+01:00 Saranya Kuniyil <saranyak578 at gmail.com>:
>>> Hi all,
>>> I am new to postgis and I need to find intersection of three polygons.
>>> In my table named "mytable" contains large no of polygon coordinates and
>>> grouped into three categories by adding a field called "filename".I
>>> labelled the category names as part1, part2, part3 in filename . Now I need
>>> to find all polygon which spacially intersect in three categories.
>>> I write my code as:
>>> SELECT ST_Intersection(a.geom, b.geom) as intersect_ab
>>> FROM mytable a INNER JOIN mytable b ON ST_Intersects(a.geom,b.geom)
>>> INNER JOIN mytable c ON ST_Intersects(a.geom,c.geom)
>>> WHERE ST_Overlaps(a.geom, b.geom) AND ST_Overlaps(b.geom, c.geom) AND
>>> ST_Overlaps(a.geom, c.geom) AND ST_isvalid(a.geom)='t' AND
>>> ST_isvalid(b.geom)='t' AND ST_isvalid(c.geom)='t' AND a.filename = 'part1'
>>> AND b.filename = 'part2' AND c.filename = 'part3') ;
>>> Is it correct?????
> In principle, your query is fine, but are you interested to retrieve just
> the three intersecting geometries or the resulting intersection of these
> (currently, you are selecting the intersection between part1 and part2
> geometries)? Moreover, are you interested on overlapping or intersection (I
> mean, is it fine if a part1 geometry contains a part2 or part3 ones)? I'm
> asking this because the intersects computation is faster than the overlaps
> one.
> Regards,
> Giuseppe.
> Giuseppe Broccolo - 2ndQuadrant Italy
> PostgreSQL & PostGIS Training, Services and Support
> giuseppe.broccolo at 2ndQuadrant.it | www.2ndQuadrant.it
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170221/6f65fded/attachment.html>
