[postgis-users] compiling from source code
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jul 7 15:18:08 PDT 2017
$ gcc-4.7 -v
Using built-in specs.
COLLECT_GCC=gcc-4.7
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.7/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
4.7.4-3ubuntu12' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
--enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
--program-suffix=-4.7 --enable-shared --enable-linker-build-id
--libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
--with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib
--enable-nls --with-sysroot=/ --enable-clocale=gnu
--enable-libstdcxx-debug --enable-gnu-unique-object --disable-libmudflap
--enable-plugin --with-system-zlib --enable-objc-gc --with-cloog
--enable-cloog-backend=ppl --disable-cloog-version-check
--disable-ppl-version-check --enable-multiarch --disable-werror
--with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32
--with-tune=generic --enable-checking=release --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.7.4 (Ubuntu/Linaro 4.7.4-3ubuntu12)
$ gcc-4.8 -v
COLLECT_GCC=gcc-4.8
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
4.8.5-4ubuntu2' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs
--enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr
--program-suffix=-4.8 --enable-shared --enable-linker-build-id
--with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib
--enable-libstdcxx-debug --enable-libstdcxx-time=yes
--enable-gnu-unique-object --disable-libmudflap --enable-plugin
--with-system-zlib --disable-browser-plugin --enable-java-awt=gtk
--enable-gtk-cairo
--with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre
--enable-java-home
--with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64
--with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64
--with-arch-directory=amd64
--with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
--enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64
--with-multilib-list=m32,m64,mx32 --with-tune=generic
Thread model: posix
gcc version 4.8.5 (Ubuntu 4.8.5-4ubuntu2)
$ gcc -v
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
5.4.0-6ubuntu1~16.04.4'
--with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
--enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
--prefix=/usr --program-suffix=-5 --enable-shared
--enable-linker-build-id --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --libdir=/usr/lib
--with-default-libstdcxx-abi=new --enable-gnu-unique-object
--disable-vtable-verify --enable-libmpx --enable-plugin
--enable-gtk-cairo
--with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-amd64/jre
--enable-java-home
--with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-amd64
--with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
--with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic
Thread model: posix
gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4)
On 7/7/2017 5:52 PM, Regina Obe wrote:
> Steve and Sandeep,
> Can you try gcc -v instead and let me know what that outputs?
> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1 and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
> However if I do gcc -V, I get an error on her too, so that's not the issue here:
> gcc: error: unrecognized command line option â?~-Vâ?T
> gcc: fatal error: no input files
> compilation terminated.
> However, lower case -v (which is what I think configure uses, works just fine).
> gcc -v
> outputs:
> COLLECT_GCC=gcc
> Configured with: ../src/configure -v --with-pkgversion='Debian 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --ena
> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --with-arch-32=i586 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-m
> Thread model: posix
> gcc version 5.2.1 20151010 (Debian 5.2.1-22)
> I'm not sure where Sandeep's gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
> Thanks,
> Regina
> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
> I get the same error running on Ubuntu 16.04 with:
> $ gcc -V
> gcc: error: unrecognized command line option ‘-V’
> Looks like the option should be --version
> $ gcc --version
> gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
> Copyright (C) 2015 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> -Steve
> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
> Hi,
> I am using gcc version 5.3 to compile postgis on Fedora.
> The compile fails at the configure step.
> I get the error:
> configure: error: C preprocessor "gcc" fails sanity check
> See `config.log' for more details
> The relevant line in config.log:
> configure:3031: gcc -v >&5
> Reading specs from
> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0/specs
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
> Target: x86_64-unknown-linux-gnu
> Configured with: ../configure
> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5
> --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib
> --enable-libstdcxx-time=yes --enable-stage1-checking
> --enable-checking=release --enable-lto
> --with-build-config=bootstrap-debug --disable-werror
> --with-pkgversion='Homebrew gcc 5.3.0'
> --with-bugurl=https://github.com/Homebrew/homebrew/issues
> --enable-plugin --disable-nls --disable-multilib
> Thread model: posix
> gcc version 5.3.0 (Homebrew gcc 5.3.0)
> configure:3042: $? = 0
> configure:3031: gcc -V >&5
> gcc: error: unrecognized command line option '-V'
> It seems gcc does not like "-V" option. I this a issue to with later
> gcc versions?
> Thanks.
> sandeep
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
