[postgis-users] compiling from source code
Sandeep Gupta
gupta.sandeep at gmail.com
Mon Jul 10 13:50:19 PDT 2017
No I didn't used the solution from that post.
I don't see any mention of 4.8 in any files or in the environment variable.
I started afresh and still end up with gcc-4.8 for linking.
On Mon, Jul 10, 2017 at 4:38 PM, Regina Obe <lr at pcorp.us> wrote:
> Perhaps you had set it as part of what the answer described here when experimenting
> https://stackoverflow.com/questions/23338713/homebrew-how-to-permanently-override-homebrew-cc-homebrew-cxx-env-settings
> I assume you just need to reset the HOMEBREW_CC HOMEBREW_CX to nothing or what it was before.
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandeep Gupta
> Sent: Monday, July 10, 2017 3:38 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] compiling from source code
> It turned out the problem wasl related to compiling conftest.c:
> configure:6858: gcc conftest.c
> conftest.c:14:8: error: unknown type name 'Syntax'
> Syntax error
> conftest.c:14:8: error: expected '=', ',', ';', 'asm' or '__attribute__' at end of input
> configure:6858: $? = 1
> configure: failed program was:
> | /* confdefs.h */
> | #define PACKAGE_NAME ""
> | #define PACKAGE_TARNAME ""
> | #define PACKAGE_VERSION ""
> | #define PACKAGE_STRING ""
> | #define PACKAGE_BUGREPORT ""
> | #define PACKAGE_URL ""
> | /* end confdefs.h. */
> | #ifdef __STDC__
> | # include <limits.h>
> | #else
> | # include <assert.h>
> | #endif
> | Syntax error
> Syntax error
> It is related to the problem posted here:
> https://stackoverflow.com/questions/15041937/configure-error-c-preprocessor-fails-sanity-check'
> Passing -E option as follows fixes the problem ( i am not sure why):
> ./configure --prefix=/home/linuxbrew/.linuxbrew/Cellar/postgis/2.3.3
> CC=/home/linuxbrew/.linuxbrew/bin/gcc
> CXX=/home/linuxbrew/.linuxbrew/bin/g++
> CPP='/home/linuxbrew/.linuxbrew/bin/g++ -E
> However the compile fails here (this is for postgis 2.3.3):
> make[1]: Entering directory
> '/home/sandeep/.cache/Homebrew/postgis-2.3.3/postgis'
> gcc-4.8 -I../liblwgeom -fpic -I../libpgcommon -I/home/linuxbrew/.linuxbrew/Cellar/geos/3.6.1/include
> -I/home/linuxbrew/.linuxbrew/Cellar/libxml2/2.9.4_3/include/libxml2
> -I/home/linuxbrew/.linuxbrew/Cellar/sfcgal/1.3.1/include -DHAVE_SFCGAL
> -fPIC -I/home/linuxbrew/.linuxbrew/Cellar/sfcgal/1.3.1/include
> -DHAVE_SFCGAL -I. -I./
> -I/home/linuxbrew/.linuxbrew/Cellar/postgresql/9.6.3/include/server
> -I/home/linuxbrew/.linuxbrew/Cellar/postgresql/9.6.3/include/internal
> -I/home/linuxbrew/.linuxbrew/opt/openssl/include
> -I/home/linuxbrew/.linuxbrew/opt/readline/include -D_GNU_SOURCE
> -I/home/linuxbrew/.linuxbrew/Cellar/libxml2/2.9.4_2/include/libxml2
> -c -o postgis_module.o postgis_module.c
> make[1]: gcc-4.8: Command not found
> <builtin>: recipe for target 'postgis_module.o' failed
> make[1]: *** [postgis_module.o] Error 127
> I am not sure why the make is picking up gcc-4.8.
> Thanks
> sandeep
> On Mon, Jul 10, 2017 at 2:42 PM, Regina Obe <lr at pcorp.us> wrote:
>> Sandeep,
>> Sounds like you might be having the same issue described here:
>> Does the suggested answer work.
>> Thanks,
>> Regina
>> Sent: Monday, July 10, 2017 2:12 PM
>> Hi Regina,
>> I tried several version of postgis (2.3.3, 2.4.0dev, 2.1.8). I have pkg_config installed on my system.
>> The error I get is:
>> checking how to run the C preprocessor... gcc
>> configure: error: in `/home/sandeep/.cache/Homebrew/postgis-2.3.3':
>> configure: error: C preprocessor "gcc" fails sanity check
>> The configure doesn't proceed after this in my case.
>> Is there any temporary workaround that you suggest I can try?
>> Thanks.
>> sandeep
>> On Sat, Jul 8, 2017 at 7:40 PM, Regina Obe <lr at pcorp.us> wrote:
>>> Sandeep,
>>> Which version of PostGIS are you trying to build? Your configure might be ending for another reason. For example in PostGIS 2.4, I think we now have a dependency on pkg-config which older versions of PostGIS do not. We'll sort this out before PostGIS release, but I think downside at moment, is the it fails if pkg-config is not installed. I forget the exact error you get.
>>> I looked around on net for the -V and from what I can tell, that error is harmless and is just part of the process of configure checking the capabilities of the gcc compile.
>>> I checked my own config.log and see the same error
>>> configure:2948: x86_64-w64-mingw32-gcc -V >&5
>>> x86_64-w64-mingw32-gcc.exe: error: unrecognized command line option '-V'
>>> x86_64-w64-mingw32-gcc.exe: fatal error: no input files compilation
>>> terminated.
>>> But my configure continues, works fine and in the end shows this:
>>> configure:20134: result:
>>> configure:20136: result: PostGIS is now configured for x86_64-w64-mingw32
>>> configure:20138: result:
>>> configure:20140: result: -------------- Compiler Info -------------
>>> configure:20142: result: C compiler: x86_64-w64-mingw32-gcc -g -O2
>>> configure:20144: result: SQL preprocessor: /mingw64/bin/cpp -traditional-cpp -w -P
>>> configure:20146: result:
>>> configure:20148: result: -------------- Dependencies --------------
>>> configure:20150: result: GEOS config: /projects/geos/rel-3.7.0devw64gcc48/bin/geos-config
>>> configure:20152: result: GEOS version: 3.7.0dev
>>> configure:20155: result: GDAL config: /projects/gdal/rel-2.2.1w64gcc48/bin/gdal-config
>>> configure:20157: result: GDAL version: 2.2.1
>>> configure:20161: result: SFCGAL config: /projects/CGAL/rel-sfcgal-1.3.0w64gcc48/bin/sfcgal-config
>>> configure:20163: result: SFCGAL version: 1.3.0
>>> configure:20167: result: PostgreSQL config: /projects/postgresql/rel/pg9.4w64gcc48/bin/pg_config
>>> configure:20169: result: PostgreSQL version: PostgreSQL 9.4.5
>>> configure:20175: result: PROJ4 version: 49
>>> configure:20177: result: Libxml2 config: /projects/libxml/rel-libxml2-2.7.8w64gcc48/bin/xml2-config
>>> configure:20179: result: Libxml2 version: 2.7.8
>>> configure:20181: result: JSON-C support: yes
>>> configure:20183: result: protobuf-c support: yes
>>> configure:20185: result: PCRE support: yes
>>> configure:20187: result: PostGIS debug level: 0
>>> configure:20189: result: Perl: /usr/bin/perl
>>> configure:20191: result:
>>> configure:20193: result: --------------- Extensions ---------------
>>> configure:20196: result: PostGIS Raster: enabled
>>> configure:20204: result: PostGIS Topology: enabled
>>> configure:20211: result: SFCGAL support: enabled
>>> configure:20219: result: Address Standardizer support: enabled
>>> configure:20225: result:
>>> configure:20227: result: -------- Documentation Generation --------
>>> configure:20229: result: xsltproc: /projects/xsltproc/xsltproc
>>> configure:20231: result: xsl style sheets: /projects/docbook/docbook-xsl-1.76.1
>>> configure:20233: result: dblatex:
>>> configure:20235: result: convert: /c/Windows/System32/convert
>>> configure:20237: result: mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>> Do you get an output anything like this or does it just end after that terminated?
>>> Thanks,
>>> Regina
>>> Sent: Friday, July 07, 2017 8:36 PM
>>> Autoconf was missing, so I went ahead install autoconf, automake, and libtool.
>>> Tried recompiling.
>>> sh autogen.sh outputs:
>>> * Running /home/linuxbrew/.linuxbrew/bin/glibtoolize (2.4.6)
>>> OPTIONS = --force --copy --install
>>> glibtoolize: putting auxiliary files in '.'.
>>> glibtoolize: copying file './config.guess'
>>> glibtoolize: copying file './config.sub'
>>> glibtoolize: copying file './install-sh'
>>> glibtoolize: copying file './ltmain.sh'
>>> glibtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
>>> glibtoolize: copying file 'macros/libtool.m4'
>>> glibtoolize: copying file 'macros/ltoptions.m4'
>>> glibtoolize: copying file 'macros/ltsugar.m4'
>>> glibtoolize: copying file 'macros/ltversion.m4'
>>> glibtoolize: copying file 'macros/lt~obsolete.m4'
>>> glibtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
>>> * Running /home/linuxbrew/.linuxbrew/bin/aclocal (1.15.1)
>>> * Running /home/linuxbrew/.linuxbrew/bin/autoconf (2.69)
>>> Now you are ready to run './configure'
>>> This does not solve though. When I run ./configure same error appears with -V flag being the issue.
>>> -sandeep
>>> On Fri, Jul 7, 2017 at 6:33 PM, Regina Obe <lr at pcorp.us> wrote:
>>>> Okay I just got an irc note from Even Roualt. He is running Ubuntu
>>>> 16.04 and gcc 5.4 and had no issue running
>>>> sh autogen.sh
>>>> ./configure
>>>> So doesn't seem like it's a newer gcc issue unless if its 5.3 specific.
>>>> I'm suspecting something with brew, MacOS, or tool chain like autoconf.
>>>> What does:
>>>> autoconf --version
>>>> Return?
>>>> I get
>>>> autoconf (GNU Autoconf) 2.69
>>>> Copyright (C) 2012 Free Software Foundation, Inc.
>>>> License GPLv3+/Autoconf: GNU GPL version 3 or later
>>>> Thanks,
>>>> Regina
>>>> Sent: Friday, July 07, 2017 6:18 PM
>>>> Hi Regina,
>>>> Here is the output for gcc -v (install gcc from linuxbrew, which port of brew package manager of macOS):
>>>> Reading specs from
>>>> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-l
>>>> i
>>>> n
>>>> ux-gnu/5.3.0/specs
>>>> COLLECT_GCC=gcc
>>>> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libe
>>>> x e c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
>>>> Target: x86_64-unknown-linux-gnu
>>>> Configured with: ../configure
>>>> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
>>>> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5
>>>> --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
>>>> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
>>>> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
>>>> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.3.0'
>>>> --with-bugurl=https://github.com/Homebrew/homebrew/issues
>>>> --enable-plugin --disable-nls --disable-multilib Thread model: posix
>>>> gcc version 5.3.0 (Homebrew gcc 5.3.0)
>>>> Thanks.
>>>> sandeep
>>>> On Fri, Jul 7, 2017 at 5:52 PM, Regina Obe <lr at pcorp.us> wrote:
>>>>> Steve and Sandeep,
>>>>> Can you try gcc -v instead and let me know what that outputs?
>>>>> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1 and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
>>>>> However if I do gcc -V, I get an error on her too, so that's not the issue here:
>>>>> gcc: error: unrecognized command line option ?~-V ?T
>>>>> gcc: fatal error: no input files
>>>>> compilation terminated.
>>>>> However, lower case -v (which is what I think configure uses, works just fine).
>>>>> gcc -v
>>>>> outputs:
>>>>> Using built-in specs.
>>>>> COLLECT_GCC=gcc
>>>>> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
>>>>> Target: x86_64-linux-gnu
>>>>> Configured with: ../src/configure -v --with-pkgversion='Debian
>>>>> 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
>>>>> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
>>>>> --prefix=/usr --program-suffix=-5 --enable-shared --ena
>>>>> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
>>>>> --with-arch-directory=amd64
>>>>> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
>>>>> --enable-multiarch --with-arch-32=i586 --with-abi=m64
>>>>> --with-multilib-list=m32,m64,mx32 --enable-m Thread model: posix
>>>>> gcc version 5.2.1 20151010 (Debian 5.2.1-22)
>>>>> I'm not sure where Sandeep's gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
>>>>> Thanks,
>>>>> Regina
>>>>> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
>>>>> I get the same error running on Ubuntu 16.04 with:
>>>>> $ gcc -V
>>>>> gcc: error: unrecognized command line option -V
>>>>> Looks like the option should be --version $ gcc --version gcc
>>>>> (Ubuntu
>>>>> 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 Copyright (C) 2015 Free
>>>>> This is free software; see the source for copying conditions.
>>>>> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
>>>>> -Steve
>>>>> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
>>>>> Hi,
>>>>> I am using gcc version 5.3 to compile postgis on Fedora.
>>>>> The compile fails at the configure step.
>>>>> I get the error:
>>>>> configure: error: C preprocessor "gcc" fails sanity check See
>>>>> `config.log' for more details
>>>>> The relevant line in config.log:
>>>>> configure:3031: gcc -v >&5
>>>>> Reading specs from
>>>>> l
>>>>> i
>>>>> n
>>>>> ux-gnu/5.3.0/specs
>>>>> COLLECT_GCC=gcc
>>>>> e x e c/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
>>>>> posix gcc version 5.3.0 (Homebrew gcc 5.3.0)
>>>>> configure:3042: $? = 0
>>>>> configure:3031: gcc -V >&5
>>>>> gcc: error: unrecognized command line option '-V'
>>>>> It seems gcc does not like "-V" option. I this a issue to with
>>>>> later gcc versions?
>>>>> Thanks.
>>>>> sandeep
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>>>> This email has been checked for viruses by Avast antivirus software.
>>>>> https://www.avast.com/antivirus
