[postgis-users] <-> operator does not return true distance
Jakob Miksch
Jakob.Miksch at nina.no
Thu Jul 13 01:26:38 PDT 2017
(I asked a similar question here https://gis.stackexchange.com/questions/247034/postgis-operator-does-not-return-true-distance )
I used the <-> operator with PostGIS 2.2.2 and PostgreSQL 9.5.7 .
According to the docs (http://postgis.net/docs/manual-2.2/geometry_distance_knn.html) the <-> operator should order by "true KNN distance" and *not* by "centroid distance".
However it does not work for me. See the minimal example below:
( illustration: https://i.stack.imgur.com/QZA6D.png )
SELECT id,
ST_Distance(my_point.geom,
my_polygons.geom) AS real_distance,
ST_Centroid(my_polygons.geom)) AS centroid_distance
FROM (
SELECT 'blue' AS id, ST_Polygon(ST_GeomFromText('LINESTRING(0 3, 2 3, 2 4, 0 4 ,0 3)'),4326) AS geom
UNION
SELECT 'green' AS id, ST_Polygon(ST_GeomFromText('LINESTRING(2 0, 8 0 , 8 2, 2 2 ,2 0)'),4326) AS geom
) AS my_polygons,
SELECT ST_SetSRID(ST_Point(1, 1),4326) AS geom
) AS my_point
ORDER BY my_point.geom <-> my_polygons.geom
--- obtained Result:
| | real_distance | centroid_distance |
| blue | 2 | 2.5 |
| green | 1 | 4 |
(I expected the rows to be in the opposite order)
Apparently the <-> operator orders by the centroid_distance and not by the real_distance, even though the docs say: "[...] for PostgreSQL 9.5+, does true KNN distance search giving true distance between geometries [...]"
I tried the same example on 2.3.2 and PostgreSQL 9.5.7 and I get the expected result (which orders by "real_distance").
So, for me it seems that ordering by "real_distance" with the <-> operator does not work with PostGIS 2.2.2 - but this is *not* written in the docs.
Can you reproduce this behaviour? Or did I understand/make something wrong here?
Thanks and best regards,
Jakob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170713/9ccb9735/attachment.html>
