[postgis-users] clone schema - pg_get_serial_sequence returns null
Olivier Leprêtre
o.lepretre at gmail.com
Sun Jul 30 11:23:38 PDT 2017
I want to clone a schema, so I wrote the script below. My problem is that I
cant get sequences with pg_get_serial_sequence for the cloned primary keys.
The sequence seems to be ok in the cloned schema :
idapp integer NOT NULL DEFAULT nextval('pr_1_1.ptbt_idapp_seq'::regclass),
CONSTRAINT adn_ptbt_pkey PRIMARY KEY (idapp)
But if I run select pg_get_serial_sequence('pr_1_1.ptbt', 'idapp') it
returns <NULL>
Conversely, running pg_get_serial_sequence('source.ptbt', 'idapp') (from the
source schema) returns the correct sequence.
Im using 9.6, I saw that it could be a problem because column is not
directly as serial, is this an answer without solution ?
Any help will be appreciated !
Thanks,
Olivier
CREATE OR REPLACE FUNCTION params.prm_colne_schema(source_schema text,
dest_schema text) RETURNS boolean AS
$BODY$
DECLARE
object text;
buffer text;
default_ text;
column_ text;
sqls text;
BEGIN
IF dest_schema <> 'public' THEN
EXECUTE 'DROP SCHEMA if exists ' || dest_schema || '
CASCADE';
EXECUTE 'CREATE SCHEMA ' || dest_schema;
END IF;
-- copy sequences
FOR object IN
SELECT sequence_name::text FROM
information_schema.SEQUENCES WHERE sequence_schema = source_schema
LOOP
EXECUTE 'CREATE SEQUENCE ' || dest_schema || '.' ||
object;
END LOOP;
-- copy tables without constraints
FOR object IN
SELECT TABLE_NAME::text FROM
information_schema.TABLES WHERE table_schema = source_schema and
substr(table_name,1,4) <> 'src_'
LOOP
buffer := dest_schema || '.' || object;
EXECUTE 'CREATE TABLE ' || buffer || ' (LIKE ' ||
source_schema || '.' || object || ' INCLUDING DEFAULTS)';
FOR column_, default_ IN
SELECT column_name::text,
REPLACE(column_default::text, source_schema, dest_schema) FROM
information_schema.COLUMNS WHERE table_schema = dest_schema AND TABLE_NAME =
object
LOOP
EXECUTE 'ALTER TABLE ' || buffer || '
ALTER COLUMN ' || column_ ||' DROP NOT NULL;';
END LOOP;
END LOOP;
-- copy tables with constraints
FOR object IN
substr(table_name,1,4) = 'src_'
LOOP
source_schema || '.' || object || ' INCLUDING ALL)';
-- copy sequences
object AND column_default LIKE 'nextval(%' || source_schema ||
'%::regclass)'
LOOP
sqls='ALTER TABLE ' || buffer || ' ALTER
COLUMN ' || column_ || ' SET DEFAULT ' || default_;
RAISE NOTICE 'default=%',sqls;
EXECUTE (sqls);
END LOOP;
END LOOP;
RETURN true;
EXCEPTION
WHEN others THEN
RETURN false;
END;
$BODY$
LANGUAGE plpgsql VOLATILE;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170730/65cfebbd/attachment.html>
