[postgis-users] PostGIS ST_EuclideanDistance() not working. Wrong upperleftx and y?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Jun 22 10:54:24 PDT 2017
Try setting the ST_MakeEmptyRaster() upperlefty parameter to a negative value (-1).
Pierre
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Vitor Sapucaia
Envoyé : 21 juin 2017 04:58
À : postgis-users at lists.osgeo.org
Objet : [postgis-users] PostGIS ST_EuclideanDistance() not working. Wrong upperleftx and y?
Hello guys!
I need help on this question that I've posted on GIS stackexchange:
https://gis.stackexchange.com/questions/244622/postgis-st-euclideandistance-not-working-wrong-upperleftx-and-y?noredirect=1#comment383015_244622
here is the question:
I'm trying to make this ST_EuclideanDistance() function work, but no success so far. I'm not getting the expected result because the raster seems to be drawn at a wrong location.
Documentation:
https://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools
Firstly, I'm considering this test page to test the function:
https://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools/test
When running the second test case:
CREATE TABLE test_source_raster_1 AS
SELECT
1 AS rid, rast
FROM
(SELECT
ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast
) foo;
CREATE TABLE test_source_geometry_1 AS
SELECT
generate_series(1,10) AS id,
ST_RandomPoints(the_geom,10) AS the_geom
FROM
(SELECT
ST_SetSRID(ST_Extent(rast::geometry), 4326) AS the_geom
FROM test_source_raster_1) foo;
CREATE TABLE test_ref_raster_1 AS
SELECT
1 AS rid, rast
FROM
(SELECT
) foo;
CREATE TABLE test_eudist_1_a_i_1 AS
(SELECT
1 AS rid,
rast,'32BF','public',
'test_source_geometry_1', 'the_geom', True
) AS rast
FROM test_ref_raster_1);
I'm getting this result (every raster pixel is null):
[results]<https://i.stack.imgur.com/xPn7Z.png>
And this is the expected result I should have gotten:
[expected]<https://trac.osgeo.org/postgis/raw-attachment/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools/test/test_eudist_1_a_i_1.gif>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170622/83de9ab6/attachment.html>
