[postgis-users] Strange behavior with empty geometries GROUP BY
Regina Obe
lr at pcorp.us
Fri Jun 23 20:26:26 PDT 2017
Pierre,
Thanks for pointing out the issue. Sandro has fixed the problem
https://trac.osgeo.org/postgis/ticket/3777#comment:17
Can you try with your larger workload. If you happen to have a windows box,
64-bit pre-compiled binaries here:
http://postgis.net/windows_downloads/
(I have 32-bit building turned off at moment cause it errors out on the gui
tests and haven't had a chance to troubleshoot).
If you have a patched version:
SELECT postgis_full_version();
Your version should have r15450 (or above) for PostGIS 2.4 and r15451 (or
above)for PostGIS 2.3.
POSTGIS="2.3.3dev r15451" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8"
LIBJSON="0.12" RASTER
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Pierre Racine
Sent: Tuesday, June 20, 2017 5:42 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Strange behavior with empty geometries GROUP BY
When I try to count the occurrence of a number of empty geometries like
this:
SELECT ST_AsText(geom) txt, count(*)
FROM (
SELECT 'POINT(0 0)'::geometry geom
UNION ALL
UNION ALL
UNION ALL
SELECT 'POINT(0 1)'::geometry geom
UNION ALL
SELECT 'LINESTRING(0 0,0 1)'::geometry geom
UNION ALL
SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
UNION ALL
SELECT 'POINT EMPTY'::geometry geom
) foo
GROUP BY geom;
The 'GEOMETRYCOLLECTION EMPTY' and the 'POINT EMPTY' do not aggregate and I
get:
txt
count
POINT(0 0) 2
POINT EMPTY 1
POINT(0 0) 1
LINESTRING(0 0,0 1) 1
GEOMETRYCOLLECTION EMPTY 1
POINT(0 1) 1
If I remove any geometry other than the two EMPTY ones like this (I removed
the first one 'POINT(0 0)'), the two EMPTY geometries DO aggregate:
FROM (
UNION ALL
UNION ALL
UNION ALL
UNION ALL
UNION ALL
) foo
GROUP BY geom;
Result:
txt count
POINT(0 0) 2
POINT EMPTY 2
POINT(0 1) 1
Any idea why empty geometries aggregation seem so dependent on what others
geoms are in the table?
Sorry I could not build a more simple example.
Thanks,
Pierre
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170623/f4138b0b/attachment.html>
