[postgis-users] importing curved polygons
Neumann, Andreas
a.neumann at carto.net
Wed Mar 8 07:25:10 PST 2017
Hi Rich,
What GDAL/OGR version do you have? Which driver do you use? There are
two.
According to
http://www.gdal.org/drv_openfilegdb.html
and
http://www.gdal.org/drv_filegdb.html (requires ESRI FileGDB API SDK)
both versions require version 2.2 or higher.
It is quite likely that you use an older version.
Try "ogrinfo --version" to get the version.
Andreas
On 2017-03-08 16:16, Richard Greenwood wrote:
> I have received an ESRI file geodatabase with polygons containing curves that I would like to import into postgis. Using ogr2ogr the curved portion of the polygon is comprised of the chord of the curve (example below).
> Does anyone have any suggestions for importing an ESRI file geodatabase containing curved polygons?
> Thanks,
> Rich
> MULTIPOLYGON(((-11750835.4823935 5060835.88854035,-11750867.8784639 5060835.62656567,-11750871.3924507 5060835.59816625,-11750871.8264507 5060873.75984909,-11750871.2171506 5060883.12929326,-11750870.900856 5060884.35132355,-11750864.5457614 5060884.41587281,-11750835.8933664 5060856.50810022,-11750835.4823935 5060835.88854035)))
> Richard W. Greenwood, PLS
> www.greenwoodmap.com [1]
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Links:
[1] http://www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170308/366bedac/attachment.html>
