[postgis-users] is ST_ConvexHull supposed to work like this?
Martijn Meijers b.m.meijers at tudelft.nl
Wed Mar 15 04:17:03 PDT 2017
Does 'supports 3d' not mean in this context in the documentation: the
function does not forget about each z coordinate of the input in the end
result, but does not take it into account inside the calculation/analysis?
It seems to me that the convex hull resulting is around the x-y
coordinates, but for the extreme points the z-coordinate will be present
in the result (so convex hull while looking from above ;-)
select st_astext(st_convexhull(st_geomfromtext(
'MULTIPOINTZ(
0 0 0
,1 0 0
,1 1 0
,0 1 0
,0 1 1
,2 2 1
,1 0 1
,0 0 1
                   st_astext
  POLYGON Z ((0 0 0,0 1 0,2 2 1,1 0 0,0 0 0))
The z=1 for point 2,2,1 is preserved however...
Martijn
On 15-03-17 12:09, Frans Knibbe wrote:
> Hello,
> I am looking for a way to describe a 3D feature that has only partial
> geometric coverage with a contiguous geometry. It seemed to me that
> ST_ConvexHull could be helpful there. But the results are not as
> expected. So I tried a simple test query to get the convex hull of the
> eight corners of a cube. The expected result would be a geometry
> describing the faces of the cube but instead I get only the bottom face:
> _query:_
> 'MULTIPOINTZ(
> 0 0 0
> ,1 0 0
> ,1 1 0
> ,0 1 0
> ,0 1 1
> ,1 1 1
> ,1 0 1
> ,0 0 1
> _result:_
> _
> _
> POLYGON Z ((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))
> This is with PostGIS 2.2.1.
> The current description of ST_ConvexHull reads "The convex hull of a
> geometry represents the minimum convex geometry that encloses all
> geometries within the set". It also says "This function supports 3d".
> The test result seems to contradict those statements.
> So is ST_ConvexHull operating as expected? If it is, could there be
> another way to get the desired result in PostGIS?
> Regards,
> Frans
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
