[postgis-users] Timezone for a given lat/long
Jorge Gustavo Rocha
jgr at di.uminho.pt
Wed Mar 22 14:35:19 PDT 2017
You can import the timezone shapefile [1] in postgis and then use the
st_contains function to return the proper timezone id. Make sure you use
a GIST index. The timezone table has 27742 rows. If you have points at
the sea, maybe this shapefile is not suitable. Try to find a another one.
[1] http://efele.net/maps/tz/world/
If you have trouble with the query, post here your attempt and we will
try to help.
Regards,
Jorge Gustavo
Às 21:23 de 22-03-2017, suraj birla escreveu:
> How to find the timezone for a given lat/long using postgis?
> We have to requirement to fnd the local timezone for millions of records
> which has UTC timestamp and lat/long info.
> Google provide API but it's single request per call.. Not feasible for
> milion records.
> Any suggestion?
> Thanks
> Suraj
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
