[postgis-users] Error compiling postgis 2.3.5 and 2.4.2
Nahum Castro
nahumcastro at gmail.com
Thu Nov 23 20:58:32 PST 2017
I have an odd error while compiling the last postgis versions
My OS is Centos Linux 7 x86_64
This is the error (the same on both versions):
make[2]: se ingresa al directorio
`/home/nahum/Descargas/postgis-2.3.5/raster/loader'
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core
-I../../liblwgeom -I/usr/local/include -I/usr/local/include -c
raster2pgsql.c
/bin/sh ../../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/usr/local/include
-I/usr/local/include ../rt_core/librtcore.a raster2pgsql.o
../../liblwgeom/liblwgeom.la -L/usr/local/lib -lgdal -L/usr/local/lib
-lgeos_c -lc -lm -o raster2pgsql
libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
-I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib -L/usr/lib64 -lSFCGAL
/usr/local/lib/libgdal.so /usr/local/lib/libproj.so -ljson-c -lsqlite3
-lodbc -lodbcinst -lexpat -lpq -lpthread -lrt -lpcre -lcurl -lxml2 -lz -ldl
/usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm
/usr/bin/ld: cannot find -lpq
collect2: error: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[2]: se sale del directorio
make[1]: *** [rtloader] Error 2
make[1]: se sale del directorio `/home/nahum/Descargas/postgis-2.3.5/raster'
make: *** [all] Error 1
Heres is the configure result:
2.3.5:
PostGIS is now configured for x86_64-unknown-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.6.2
GDAL config: /usr/local/bin/gdal-config
GDAL version: 2.2.1
SFCGAL config: /usr/bin/sfcgal-config
SFCGAL version: 1.2.2
PostgreSQL config: /usr/local/pgsql/bin/pg_config
PostgreSQL version: PostgreSQL 10.1
PROJ4 version: 49
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.1
JSON-C support: yes
PCRE support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: enabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
dblatex:
convert: /usr/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
And 2.4.2
GEOS version: 3.6.2
GDAL version: 2.2.1
PROJ4 version: 49
JSON-C support: yes
protobuf-c support: no
PCRE support: yes
Perl: /usr/bin/perl
dblatex:
configure: WARNING: --------- GEOS VERSION WARNING ------------
configure: WARNING: You are building against GEOS 3.6.2
configure: WARNING: To take advantage of all the features of
configure: WARNING: this PostGIS version requires GEOS 3.7.0 or higher
which is not out yet.
configure: WARNING: To take advantage of most of the features of this
configure: WARNING: we recommend GEOS 3.6 or higher
configure: WARNING: You can download the latest versions from
configure: WARNING: http://trac.osgeo.org/geos
configure: WARNING:
And here is the output from ldconfig.
/usr/local/pgsql/lib:
libpqwalreceiver.so -> libpqwalreceiver.so
libpgrouting-2.4.so -> libpgrouting-2.4.so
libecpg_compat.so.3 -> libecpg_compat.so.3.10
libecpg.so.6 -> libecpg.so.6.10
libpgtypes.so.3 -> libpgtypes.so.3.10
libpq.so.5 -> libpq.so.5.10
The last line contains libpq.
Everything is compiled from source gdal, geos, proj, postgresql.
The only thing is that I upgraded from postgresql 9.6.6 and postgis 2.3.3
Here is my pg_config
[nahum at localhost postgis-2.4.2]$ pg_config
BINDIR = /usr/local/pgsql/bin
DOCDIR = /usr/local/pgsql/share/doc
HTMLDIR = /usr/local/pgsql/share/doc
INCLUDEDIR = /usr/local/pgsql/include
PKGINCLUDEDIR = /usr/local/pgsql/include
INCLUDEDIR-SERVER = /usr/local/pgsql/include/server
LIBDIR = /usr/local/pgsql/lib
PKGLIBDIR = /usr/local/pgsql/lib
LOCALEDIR = /usr/local/pgsql/share/locale
MANDIR = /usr/local/pgsql/share/man
SHAREDIR = /usr/local/pgsql/share
SYSCONFDIR = /usr/local/pgsql/etc
PGXS = /usr/local/pgsql/lib/pgxs/src/makefiles/pgxs.mk
CONFIGURE = '--enable-nls=es' '--with-openssl' '--with-libxml'
'--with-libxslt' '--with-selinux' '--with-ldap' '--with-perl'
'--with-python'
CC = gcc
CPPFLAGS = -DFRONTEND -D_GNU_SOURCE -I/usr/include/libxml2
CFLAGS = -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute
-Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard
-O2
CFLAGS_SL = -fPIC
LDFLAGS = -L../../src/common -Wl,--as-needed
-Wl,-rpath,'/usr/local/pgsql/lib',--enable-new-dtags
LDFLAGS_EX =
LDFLAGS_SL =
LIBS = -lpgcommon -lpgport -lpthread -lselinux -lxslt -lxml2 -lssl -lcrypto
-lz -lreadline -lrt -lcrypt -ldl -lm
VERSION = PostgreSQL 10.1
Can you help me on how to find where is my error. I googled and found a
similar error on postgresql 8 and postgis 1.5
In https://www.postgresql.org/docs/current/static/libpq-build.html
says that "This means you forgot the -L option or did not specify the right
directory." but I don't know if it is related.
Thanks in advance.
Nahum
*Nahum Castro González*
Blvd. Perdigón 214, Brisas del Lago.
CP 37207
León, Guanajuato, México
Tel (477)1950304
Cel (477)1274694
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171123/e5f8ddf6/attachment.html>
