[postgis-users] TR: strange behavior of ST_Area(geography)
IIDA Tetsushi
hogeman at gmail.com
Sun Oct 15 06:07:59 PDT 2017
thank you, Olivier.
sorry, i forgot to describe my environment.
PostgreSQL 9.6.3 on x86_64-pc-linux-gnu, compiled by gcc (Debian
4.9.2-10) 4.9.2, 64-bit
POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel.
4.8.0, 6 March 2012" GDAL="GDAL 1.10.1,
released 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
(docker image "mdillon/postgis")
2017-10-15 21:34 GMT+09:00 Olivier Leprêtre <o.lepretre at gmail.com>:
> 9.6 and
> "POSTGIS="2.3.2 r15302" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8" LIBJSON="0.12" TOPOLOGY RASTER"
> -----Message d'origine-----
> De : Olivier Leprêtre [mailto:o.lepretre at gmail.com]
> Envoyé : dimanche 15 octobre 2017 14:33
> À : 'PostGIS Users Discussion'
> Objet : RE: [postgis-users] strange behavior of ST_Area(geography)
> I tested your query with 9.6 all tests return true.
> Olivier
> De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de IIDA Tetsushi Envoyé : dimanche 15 octobre 2017 13:42 À : postgis-users at lists.osgeo.org Objet : [postgis-users] strange behavior of ST_Area(geography)
> Hi,
> These polygons have the same shape but orientation.
> --- my query -----
> WITH poly AS (
> SELECT
> ST_SetSRID(ST_GeomFromText(
> 'POLYGON((138.002 37.001, 138.003 37.0010, 138.003 37.0013, 138.002 37.001))'
> ),4326) g1,
> 'POLYGON((138.002 37.001, 138.003 37.0013, 138.003 37.0010, 138.002 37.001))'
> ),4326) g2
> SELECT ST_Equals(g1,g2),
> ST_Area(g1) = ST_Area(g2) AS eq_area,
> ST_Area(g1::geography) = ST_Area(g2::geography) AS geog1,
> ST_Area(g1::geography, false) = ST_Area(g2::geography, false) AS geog2,
> ST_Area(g1::geography) = ST_Area(ST_Reverse(g2)::geography) AS geog3,
> ST_Area(ST_Transform(g1,32654)) = ST_Area(ST_Transform(g2,32654)) AS geom FROM poly;
> ----- output -----
> st_equals | eq_area | geog1 | geog2 | geog3 | geom
> t | t | f | t | t | t
> I expected all these tests return true.
> Is this behavior by spec?
> Thanks
> hogeman
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
> https://www.avast.com/antivirus
Iida, Tetsushi
飯田 哲士
