[postgis-users] TR: strange behavior of ST_Area(geography)
Ben Madin ben at ausvet.com.au
Mon Oct 16 06:05:23 PDT 2017
Works for me ... from the small sample size, it would appear that the
version of GDAL you have compiled against (I am using 2.1.3, as is Olivier)
might need to be updated from the 2013 release.
hth
Ben
On 16 October 2017 at 23:48, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Werks fer me also:
>  st_equals | eq_area | geog1 | geog2 | geog3 | geom
>  t         | t       | t     | t     | t     | t
> On Sun, Oct 15, 2017 at 6:07 AM, IIDA Tetsushi <hogeman at gmail.com> wrote:
>> thank you, Olivier.
>> sorry, i forgot to describe my environment.
>>  PostgreSQL 9.6.3 on x86_64-pc-linux-gnu, compiled by gcc (Debian
>> 4.9.2-10) 4.9.2, 64-bit
>>  POSTGIS="2.3.2 r15302" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel.
>> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1,
>>  released 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
>> (docker image "mdillon/postgis")
>> 2017-10-15 21:34 GMT+09:00 Olivier Leprêtre <o.lepretre at gmail.com>:
>> > 9.6 and
>> > "POSTGIS="2.3.2 r15302" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel.
>> 4.9.1, 04 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8"
>> LIBJSON="0.12" TOPOLOGY RASTER"
>> > -----Message d'origine-----
>> > De : Olivier Leprêtre [mailto:o.lepretre at gmail.com]
>> > Envoyé : dimanche 15 octobre 2017 14:33
>> > À : 'PostGIS Users Discussion'
>> > Objet : RE: [postgis-users] strange behavior of ST_Area(geography)
>> > I tested your query with 9.6 all tests return true.
>> > Olivier
>> > De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De
>> la part de IIDA Tetsushi Envoyé : dimanche 15 octobre 2017 13:42 À :
>> postgis-users at lists.osgeo.org Objet : [postgis-users] strange behavior
>> > Hi,
>> > These polygons have the same shape but orientation.
>> > --- my query -----
>> > WITH poly AS (
>> >  SELECT
>> >   ST_SetSRID(ST_GeomFromText(
>> >    'POLYGON((138.002 37.001, 138.003 37.0010, 138.003 37.0013, 138.002
>> 37.001))'
>> >    ),4326) g1,
>> >    'POLYGON((138.002 37.001, 138.003 37.0013, 138.003 37.0010, 138.002
>> 37.001))'
>> >    ),4326) g2
>> > SELECT ST_Equals(g1,g2),
>> >  ST_Area(g1)                     = ST_Area(g2) AS eq_area,
>> >  ST_Area(g1::geography)          = ST_Area(g2::geography) AS geog1,
>> >  ST_Area(g1::geography, false)   = ST_Area(g2::geography, false) AS
>> geog2,
>> >  ST_Area(g1::geography)          = ST_Area(ST_Reverse(g2)::geography)
>> AS geog3,
>> >  ST_Area(ST_Transform(g1,32654)) = ST_Area(ST_Transform(g2,32654)) AS
>> geom  FROM poly;
>> > ----- output -----
>> >  t         | t       | f     | t     | t     | t
>> > I expected all these tests return true.
>> > Is this behavior by spec?
>> > Thanks
>> > hogeman
>> > _______________________________________________
>> > postgis-users mailing list
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
>> > L'absence de virus dans ce courrier électronique a été vérifiée par le
>> logiciel antivirus Avast.
>> > https://www.avast.com/antivirus
>> Iida, Tetsushi
>> 飯田 哲士
Dr Ben Madin
Managing Director
m : +61 448 887 220
e : ben at ausvet.com.au
5 Shuffrey Street, Fremantle
Western Australia
on the web: www.ausvet.com.au
This transmission is for the intended addressee only and is confidential
information. If you have received this transmission in error, please delete
it and notify the sender. The contents of this email are the opinion of the
writer only and are not endorsed by Ausvet unless expressly stated
otherwise. Although Ausvet uses virus scanning software we do not accept
liability for viruses or similar in any attachments.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171017/7904d48e/attachment.html>
