[postgis-users] minor change to UsersWikiSimplifyWithTopologyExt
G. Allegri
giohappy at gmail.com
Mon Oct 30 08:42:53 PDT 2017
reading the suggested SQL to generate the simplified edges geoms I thinkg a
minor change would provide more robust resolults:
Phase 3:
>select ST_Collect(st_simplifyPreserveTopology(geom, 10000)) as geom
should be canged to:
>select ST_SimplifyPreserveTopology(ST_Collect(geom), 10000)) as geom
this guarantees that topology is preserved between edge_data geometries.
This solved various issues I obtained while applying the original SQL to
some intricated geometries.
If you agree on this I can modify the wiki page directly.
All the best,
giovanni
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171030/db2f176b/attachment.html>
