[postgis-users] ST_Polygonize give different results on same set of linestrings
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Sep 7 06:59:50 PDT 2017
I simplified the example a bit, removing ST_ExteriorRing():
WITH polys AS (
SELECT ST_GeomFromText('LINESTRING(1 1, 3 2, 3 0, 1 1)') geom
UNION ALL
SELECT ST_GeomFromText('LINESTRING(2 1, 4 2, 4 0, 2 1)') geom
), extrings AS (
SELECT 1 test, geom
FROM polys
UNION ALL
SELECT 2 test, ST_Union(geom) geom
FROM polys
UNION ALL
SELECT 3 test, ST_Collect(geom) geom
FROM polys
SELECT test, ST_AsText(ST_Polygonize(geom))
FROM extrings
GROUP BY test;
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Pierre Racine
Envoyé : 7 septembre 2017 09:46
À : PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Objet : [postgis-users] ST_Polygonize give different results on same set of linestrings
Is it normal that ST_Polygonize() gives two different results depending on if the linestrings are ST_Union() before calling it or not?
In the following example, test 1 (no union) and 3 (ST_Collect) give the same result, constructing two overlapping polygons. Test 2 (ST_Union) on the other side constructs 3 disjoint polygons removing overlaps. All tests provide, however, the same basic set of linestrings to ST_Polygonize.
WITH polys AS (
SELECT ST_GeomFromText('POLYGON((1 1, 3 2, 3 0, 1 1))') geom
UNION ALL
SELECT ST_GeomFromText('POLYGON((2 1, 4 2, 4 0, 2 1))') geom
), extrings AS (
SELECT 1 test, ST_ExteriorRing(geom) geom
FROM polys
UNION ALL
SELECT 2 test, ST_Union(ST_ExteriorRing(geom)) geom
FROM polys
UNION ALL
SELECT 3 test, ST_Collect(ST_ExteriorRing(geom)) geom
FROM polys
FROM extrings
GROUP BY test;
It seems to me that only test 2 (ST_Union) returns the expected result which is to reconstruct planar polygons from a set of linestrings however they are provided.
It bothers me because I would like to get the same result as test 2 without relying on ST_Union() which seems to sometime slightly shift vertexes in order to union geometries together (true or false?).
Thanks for any explanation.
Pierre
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170907/84ece3d8/attachment.html>
