[postgis-users] PostgreSQL VS EDB performance with PostGIS
Pradeep Kanth G
pgundala at avineonindia.com
Thu Sep 21 02:40:38 PDT 2017
Hi Nicklas,
I have around 300 feature classes and each feature class having more than 1 million of rows. While querying with spatial functions(StGeoJson, Intersection etc..) it’s taking lot of time and also created spatial indexes on those layers.
So kindly let me know ,how to overcome this issue.
Regards
Pradeep Kanth
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Nicklas Avén
Sent: Thursday, September 21, 2017 2:10 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] PostgreSQL VS EDB performance with PostGIS
Hello
This question is not possible to answer without more information like:
Did you have performance problems with PostGIS under PostgreSQL?
Why do you expect better performance from moving to EDB? What functionality in EDB did you expect to impact the performance?
What is the query that is slow? There are many functions in PostGIS, what are you using. Most performance problems with PostGIS is related to not having indexes where needed, or a query written in a way so PostGIS cannot gain from indexes.
Regards
Nicklas
On Thu, 2017-09-21 at 09:20 +0530, Pradeep Kanth G wrote:
Recently , I have moved my PostGIS Spatial data from PostgreSQL to EDB(Enterprise DB) .After moving into EDB there is no much difference between Open Source PostgreSQL performance wise.
So kindly suggested to us ,how to improve the EDB performance with PostGIS.
Regards
Pradeep Kanth
Disclaimer | The information contained in this electronic message (including any attachments) is intended for the exclusive use of the addressee(s) and may contain confidential or privileged information.If you have received this in error, please notify the sender immediately and delete the material from your machine. Any action including review, retransmission, dissemination of this email or the attachments present along with the email by persons or entities other than the intended recipient is prohibited.
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170921/174f1946/attachment.html>
