[postgis-users] Create trigger latitude and longitude
Ben Madin ben at ausvet.com.au
Thu Sep 21 22:57:54 PDT 2017
Rafael,
I'd probably question why you need to do this, but it is just a routine
INSERT/UPDATE AFTER trigger function. The answers you seek are probably
covered in https://www.postgresql.org/docs/9.6/static/triggers.html
I'm presuming you know how to get the x and y coordinates for a point...
cheers
Ben
On 12 September 2017 at 17:48, Rafael Reis <rafaelreis2008 at gmail.com> wrote:
> Hi,
> I have a table of point type, and whenever i insert a point I want
> latitude and longitude (EPSG:4326) to appear in a text field of this table,
> in decimal degrees. Can anyone tell me how I should create a trigger for
> this?
> Thanks,
> Rafael
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Dr Ben Madin
Managing Director
m : +61 448 887 220 t : +61 8 9336 5022
e : ben at ausvet.com.au
Level 2 / 10 High Street, Fremantle
Western Australia
on the web: www.ausvet.com.au
This transmission is for the intended addressee only and is confidential
information. If you have received this transmission in error, please delete
it and notify the sender. The contents of this email are the opinion of the
writer only and are not endorsed by Ausvet unless expressly stated
otherwise. Although Ausvet uses virus scanning software we do not accept
liability for viruses or similar in any attachments. Thanks for reading.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170922/509e799b/attachment.html>
