[postgis-users] Problem installing PostGIS 2.4 on RH
Regina Obe lr at pcorp.us
Fri Aug 3 11:30:01 PDT 2018
You should be able to get one from
Yum.postgresql.org - https://yum.postgresql.org/repopackages.php#pg10
These instructions for using yum.postgresql.org are a bit dated, but hopefully you can follow along
http://www.postgresonline.com/journal/archives/362-An-almost-idiots-guide-to-install-PostgreSQL-9.5,-PostGIS-2.2-and-pgRouting-2.1.0-with-Yum.html
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Fabien Celaia
Sent: Friday, July 27, 2018 3:26 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Problem installing PostGIS 2.4 on RH
My RH has a yum package installing Postgresql 9.2.23 and PostGIS 2.4
postgresql.x86_64 0:9.2.23-3.el7_4
postgis24_96-2.4.4-2.rhel7.x86_64
Additionaly, I wish to install Postgresql 10.4 + the newest stable release of PostGIS (2.4?).
I already installed successfully Postgresql 10.4... it works... But I don't have the postgis extension.
I downloaded postgis-2.4.4 and unzipped it into /tmp
Isn't it possible to find a built version of postgis 2.4 on Postgresql 10.4 for RH7 ?
Cheers
Fadace
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180803/e2146584/attachment.html>
