[postgis-users] ST_Clip on tiled rasters
J Payne
jcpayne at uw.edu
Fri Feb 2 15:47:40 PST 2018
Hi. I have a problem that is driving me nuts. I’ve got an out-of-db raster table that contains a time series of images of the same area (one per date), and it is tiled. I’m trying to clip a section of it with a polygon.
If I union the tiles for a particular date and then clip them, I get the correct answer. I’ll show this in two steps for simplicity:
#1. Create a unioned raster for a single date
CREATE TABLE onedate AS (
SELECT ST_Union(rast) AS rast FROM myrastertable
WHERE image_date = '2010-01-01'
#2. Clip the unioned raster (gives the correct answer)
SELECT ST_Clip(rast, geom,true) AS rast FROM onedate, totalconvexhull
WHERE ST_Intersects(rast, geom)
…but if I try the same thing with the tiled version of the table, it fails:
#1. Create a tiled raster for the same date
CREATE TABLE onedate_tiled AS (
SELECT * FROM myrastertable WHERE image_date = '2010-01-01'
#2. Clip the tiled raster (this fails: it seems to get rid of some of the tiles where there is no overlap with the polygon, but stuff hangs over the edges of the polygon for tiles that cross the boundary of the polygon)
SELECT ST_Clip(rast, geom, true) AS rast FROM onedate_tiled, totalconvexhull
I’d love to know what I am missing. Ultimately, I want to clip all of the dates to the same polygon.
Thanks!
John
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180202/a24ca806/attachment.html>
