[postgis-users] splitting a linestring with points
Olivier Leprêtre o.lepretre at gmail.com
Fri Feb 9 04:56:10 PST 2018
Hi, thanks for your answers,
I didn't interpret well what st_split would do, I thought st_split(line, set of n points) would returns n+1 set of lines segments but in fact it returns 2 n lines, input line being cut n times. So I have to search another way, likely as Nicolas suggested with st_lineLocatePoint and st_lineSubstring, or using st_split one point at a time.
Olivier
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Alexandre Neto
Envoyé : vendredi 9 février 2018 13:31
À : PostGIS Users Discussion
Objet : Re: [postgis-users] splitting a linestring with points
Beware that hitting a line with a point can be tricky in terms of accuracy. Unless the point is snapped to one of the line's vertices, if you zoom enough, it will not be on top of the line. That may be the reason why you are not getting the desired results.
Olivier Leprêtre <o.lepretre at gmail.com> escreveu no dia sexta, 9/02/2018 às 09:55:
Hi Martin
I hoped but it's doesn't with results from st_collectionExtract(st_Split())
Olivier
-----Message d'origine-----
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Martijn Meijers
Envoyé : vendredi 9 février 2018 09:15
À : postgis-users at lists.osgeo.org
st_dump would make it possible, no?
select st_astext((st_dump('MULTILINESTRING((0 0, 10 10), (20 20, 30 30))')).geom);
         st_astext
  LINESTRING(0 0,10 10)
  LINESTRING(20 20,30 30)
(2 rows)
On 08-02-18 21:48, Olivier Leprêtre wrote:
> Hi,
> I want to break a linestring into linestrings by breaking it with a
> set of points along this line. This appeared easy at first but
> finally, I tried using st_split(line, set of points) but this returns
> multilinestrings when I just wants linestrings. I tried several
> functions like st_dump, st_geometryN, stcollectionextract and so on
> after st_split but did not find how could I get only rows of
> linestring splitted by the points acting like blades on the first
> linestring.
> Thanks for any help,
> Olivier
> <https://www.avast.com/sig-email?utm_medium=email <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> &utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>       Garanti sans virus. www.avast.com
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180209/f9164fdf/attachment.html>
