[postgis-users] ST_Polygonize bug?
Paulo Pires
paulopires16 at gmail.com
Sun Jun 3 14:36:40 PDT 2018
Hello,
Please, see this 2 polygons example.
I Convert them to linestrings (ST_Boundary) and then to polygons again
(ST_Polygonize) and I can't reach to same polygons...
This is a bug from ST_Polygonize function?
DROP TABLE IF EXISTS areas;
CREATE TABLE areas (
id integer,
geom GEOMETRY
INSERT INTO areas (id, geom) VALUES
(1, ST_GeometryFromText('POLYGON (( 152475.78309656942
348633.83643648896 100.0 , 152819.11124438787 348634.30014856393 100.0
, 152813.0950157867 348346.43594807677 100.0 , 151948.4678701025
348359.31090193643 100.0 , 151945.74402745243 348463.90645969921 100.0
, 152474.91289439827 348458.49244305107 100.0 , 152475.78309656942
348633.83643648896 100.0 ), ( 152527.33647845959 348558.83199005033
100.0 , 152529.2307245445 348407.29230325681 100.0 ,
152709.18410261182 348403.50381108694 100.0 , 152709.18410261182
348558.83199005033 100.0 , 152527.33647845959 348558.83199005033 100.0
), ( 152006.95163549151 348435.14978348627 100.0 , 152006.95163549151
348385.89938685647 100.0 , 152092.19270658147 348384.00514083228 100.0
, 152091.24558356937 348434.20266047411 100.0 , 152006.95163549151
348435.14978348627 100.0 ))')),
(2, ST_GeometryFromText('POLYGON (( 152527.33647845959
348558.83199005033 100.0 , 152709.18410261182 348558.83199005033 100.0
, 152709.18410261182 348403.50381108694 100.0 , 152529.22480595027
348407.76579079556 100.0 , 152527.33647845959 348558.83199005033 100.0
DROP TABLE IF EXISTS poly2line;
create table poly2line as
SELECT ST_Boundary((ST_Dump(geom)).geom) AS geom
FROM areas;
DROP TABLE IF EXISTS polygonize;
CREATE TABLE polygonize AS
select (st_dump(ST_Polygonize(geom))).geom as geom
from poly2line;
Paulo Pires
phone 964592113
e-mail paulopires16 at gmail.com
crypt myPGP public key for encryption emails
<http://kerckhoffs.surfnet.nl/pks/lookup?op=get&search=0x878711213981EEF6>
links facebook <http://facebook.com/paulopires16> · twitter
<http://twitter.com/#!/paulopires16> · linkedin
<http://www.linkedin.com/pub/paulo-pires/36/4a7/607> · netlog
<http://netlog.com/paulopires16> · javase
<http://download.oracle.com/javase/6/docs/api/> · oracle
<http://www.oracle.com/us/syndication/feeds/index.html>
Aviso Legal:
Esta mensagem de Paulo Pires é destinada exclusivamente ao destinatário.
Pode conter informação confidencial ou legalmente protegida. A incorrecta
transmissão desta mensagem não significa a perda de confidencialidade. Se
esta mensagem for recebida por engano, por favor envie-a de volta para o
remetente e apague-a do seu sistema de imediato. É proibido a qualquer
pessoa que não o destinatário de usar, revelar ou distribuir qualquer parte
desta mensagem.
Disclaimer:
This message from Paulo Pires is destined exclusively to the intended
receiver. It may contain confidential or legally protected information. The
incorrect transmission of this message does not mean the loss of its
confidentiality. If this message is received by mistake, please send it
back to the sender and delete it from your system immediately. It is
forbidden to any person who is not the intended receiver to use, distribute
or copy any part of this message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180603/160c1816/attachment.html>
