[postgis-users] Delete locks temp table
Paulo Pires
paulopires16 at gmail.com
Wed Jun 6 03:07:35 PDT 2018
Thanks Darafei,
See the whole process. Do you mean make just one function?
CREATE OR REPLACE FUNCTION is_internal(polygon geometry, p2
geometry, p3 geometry)
RETURNS boolean as
BEGIN
return st_contains(polygon, st_makeline(p2, p3));
END
$$ language plpgsql;
CREATE OR REPLACE FUNCTION angle(p1 geometry, p2 geometry, p3
geometry)
RETURNS float AS
DECLARE
p12 float;
p23 float;
p13 float;
BEGIN
select st_distance(p1, p2) into p12;
select st_distance(p1, p3) into p13;
select st_distance(p2, p3) into p23;
return acos( (p12^2 + p13^2 - p23^2) / (2*p12*p13) );
END
CREATE OR REPLACE FUNCTION internal_angle(polygon geometry, p1
geometry, p2 geometry, p3 geometry)
RETURNS float as
DECLARE
ang float;
is_intern boolean;
BEGIN
select temp.angle(p1, p2, p3) into ang;
select temp.is_internal(polygon, p2, p3) into is_intern;
return ang;
END
CREATE OR REPLACE FUNCTION corner_triplets(geom geometry)
RETURNS table(corner_number integer, p1 geometry, p2 geometry,
p3 geometry) AS
DECLARE
max_corner_number integer;
BEGIN
DROP TABLE IF EXISTS corners;
create temp table corners on commit drop as select
path[2] as corner_number, t1.geom as point from (select
(st_dumppoints($1)).*) as t1 where path[1] = 1;
select max(corners.corner_number) into
max_corner_number from corners;
insert into corners (corner_number, point) select 0,
point from corners where corners.corner_number = max_corner_number - 1;
DROP TABLE IF EXISTS triplets;
create temp table triplets on commit drop as select
t1.corner_number, t1.point as p1, t2.point as p2, t3.point as p3 from
corners as t1, corners as t2, corners as t3 where t1.corner_number =
t2.corner_number + 1 and t1.corner_number = t3.corner_number - 1;
return QUERY TABLE triplets;
END;
LANGUAGE plpgsql;
CREATE OR REPLACE FUNCTION internal_angles(geom geometry)
RETURNS table(corner geometry, angle float)
AS $$
BEGIN
DROP TABLE IF EXISTS internal_angs;
create temp table internal_angs on commit drop as
select p1, internal_angle(geom, p1, p2, p3) from (select (c).* from (select
corner_triplets(geom) as c) as t1) as t2;
return QUERY TABLE internal_angs;
END;
LANGUAGE plpgsql;
DROP TABLE IF EXISTS allradians;
select (c).* into allradians from (select internal_angles(geom)
as c from mytable) as t;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180606/d6e8d552/attachment.html>
