[postgis-users] Voronoi polygons for large dataset
Arnaud L. arnaud.listes at codata.eu
Mon Jun 11 04:12:25 PDT 2018
Hi Nathan
Le 07-06-18 à 17:15, Nathan Einstein a écrit :
> Unfortunately, it doesn’t seem like there’s any simple
> “divide-and-conquer”-type solution; because the Voronoi polygons on the
> edges will be irregularly shaped, I haven’t been able to come up with a
> clean way to combine the results from subsets of the full dataset.
There is a known merging algorithm, but it works only on subsets
splitted by a north-south line.
You can find the algorithm here :
http://www.personal.kent.edu/~rmuhamma/Compgeometry/MyCG/Voronoi/DivConqVor/divConqVor.htm
If you happen to end-up with a parallelizable PostGIS function, I'd be
very interested by your code ! ;)
Regards
Arnaud
