[postgis-users] Increase KNN efficiency
Vispo Leblanc
vispoleblanc at gmail.com
Wed May 30 14:07:19 PDT 2018
Hello PostGIS users,
I am looking for a way to increase the speed of my query with KNN.
I have two tables with millions of points in each table. I would like to
find the nearest neighbor (only one) of my points in table A with my points
in table B.
I wrote the following query:
WITH index_query as (
SELECT
t1.id,
t1.geom AS geom,
t2.geom AS geom2,
t1.geom <-> t2.geom AS distance
FROM research_scrapper.table1 t1,
research_scrapper.table2 t2
ORDER BY t1.geom <-> t2.geom
SELECT tbl.cas_id, tbl.geom
FROM index_query tbl
INNER JOIN
SELECT geom2,
MIN(distance) as distance
FROM index_query
GROUP BY geom2
)tbl1
ON tbl1.geom_generated=tbl.geom_generated
AND tbl1.distance = tbl.distance
This is taking forever, would you have any suggestions on how to increase
the efficiency?
Thanks for your help,
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180530/2065c600/attachment.html>
