[postgis-users] Increase KNN efficiency
Vispo Leblanc vispoleblanc at gmail.com
Thu May 31 09:05:24 PDT 2018
Thanks Nicolas, this is *way better*, I guess my previous query was
calculating all distance between all elements.
Thanks again!
On Thu, May 31, 2018 at 2:47 AM Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hi,
> Put the KNN operator in a LATERAL subquery, using LIMIT x to limit NN to x
> elements:
> SELECT
>   p1.id,
>   t.id AS id2,
>   t.dist
> FROM parc p1
>   CROSS JOIN LATERAL
>              (SELECT
>                 p2.id,
>                 st_distance(p1.geom, p2.geom) AS dist
>               FROM parc p2
>               WHERE p1.id <> p2.id
>               ORDER BY p1.geom <-> p2.geom
>               LIMIT 1) AS t
> ORDER BY p1.id, t.dist;
> Nicolas
> On 30 May 2018 at 23:07, Vispo Leblanc <vispoleblanc at gmail.com> wrote:
>> Hello PostGIS users,
>> I am looking for a way to increase the speed of my query with KNN.
>> I have two tables with millions of points in each table. I would like to
>> find the nearest neighbor (only one) of my points in table A with my points
>> in table B.
>> I wrote the following query:
>> WITH index_query as (
>>   SELECT
>>     t1.id,
>>     t1.geom AS geom,
>>     t2.geom AS geom2,
>>     t1.geom <-> t2.geom AS distance
>>   FROM research_scrapper.table1 t1,
>>       research_scrapper.table2 t2
>>   ORDER BY t1.geom <-> t2.geom
>> SELECT tbl.cas_id, tbl.geom
>> FROM index_query tbl
>> INNER JOIN
>>         SELECT geom2,
>>                MIN(distance) as distance
>>         FROM index_query
>>         GROUP BY geom2
>>     )tbl1
>>     ON tbl1.geom_generated=tbl.geom_generated
>>     AND tbl1.distance = tbl.distance
>> This is taking forever, would you have any suggestions on how to increase
>> the efficiency?
>> Thanks for your help,
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180531/d35c31ef/attachment.html>
