[postgis-users] Hi hi hello - Postgis & postgres binary
James Keener
jim at jimkeener.com
Wed Nov 14 04:31:08 PST 2018
I'm not sure what you mean by an embedded database. PostgreSQL isna stand alone database, not an embeddable one.
If you're talking about building a docker container, what base are you using? Can you use one that has access to or install more repositories?
Jim
On November 14, 2018 7:24:09 AM EST, "MichaĆ Garnysz" <garnysz.michal at gmail.com> wrote:
>I'm struggling to create working instance of postgres with postgis
>enabled
>database
>i need to have one binary file i will use as emmbedded database where i
>need call
>CREATE EXTENSION postgis;
>I tried many approaches and usually im ending up with dependency to
>container where i installed postgis or issue with unable to locate
>$libdir:postis2.5
>(other are openssl v.1.1.0 on centos/redhat)
>Is there any place i can get DB instance with already copiled binaries
>vs 1
>or 2 version?
>Hope someone have any advice/ hint im stuck on this for to long.
>Best regards Michal
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181114/7ba19650/attachment.html>
