[postgis-users] Geometry problems
Daniel Baston dbaston at gmail.com
Wed Oct 10 06:43:31 PDT 2018
Plugging the WKT directly into JTS TestBuilder shows that
equals=false, even if you paste the same WKT for both inputs. The
geometry is invalid, but I would have expected Geometry.equals() to
report a correct answer or throw an exception.
PostGIS 2.2+ should return 'true' in this case, because it does a
memcmp before ever sending the geometry to GEOSEquals.
Dan
On Wed, Oct 10, 2018 at 9:29 AM Sandro Santilli <strk at kbt.io> wrote:
> On Wed, Oct 10, 2018 at 10:07:20AM -0300, Agustin Ignacio Genoves wrote:
> > when I compared two identical geometries with the function st_equals () it
> > returns false. I give details of the geometries and the query.
> When you print the geometries in WKT form you loose precision
> (due to the limited number of decimal digits we print).
> Get an HEXWKB representation of those two geometries and I bet you'll
> find a difference.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
