[postgis-users] Geometry problems
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Wed Oct 10 06:57:03 PDT 2018
PostGIS 2.1 is End of Life and the only way to resolve issues in it should
be upgrading to latest version:
https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
ср, 10 окт. 2018 г. в 16:49, Agustin Ignacio Genoves <
agustingenoves at gmail.com>:
> Here we have installed postgis 2.1.4. I read that in version 2.2 onwards
> if they are binary equal, it returns true even if the geometry is invalid.
> El mié., 10 oct. 2018 a las 10:43, Daniel Baston (<dbaston at gmail.com>)
> escribió:
>> Plugging the WKT directly into JTS TestBuilder shows that
>> equals=false, even if you paste the same WKT for both inputs. The
>> geometry is invalid, but I would have expected Geometry.equals() to
>> report a correct answer or throw an exception.
>> PostGIS 2.2+ should return 'true' in this case, because it does a
>> memcmp before ever sending the geometry to GEOSEquals.
>> Dan
>> On Wed, Oct 10, 2018 at 9:29 AM Sandro Santilli <strk at kbt.io> wrote:
>> > On Wed, Oct 10, 2018 at 10:07:20AM -0300, Agustin Ignacio Genoves wrote:
>> > > when I compared two identical geometries with the function st_equals
>> () it
>> > > returns false. I give details of the geometries and the query.
>> > When you print the geometries in WKT form you loose precision
>> > (due to the limited number of decimal digits we print).
>> > Get an HEXWKB representation of those two geometries and I bet you'll
>> > find a difference.
>> > --strk;
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181010/570e3e5a/attachment.html>
