Le 18/10/2018 à 00:04, Shane Carey a écrit : > Is there a way to split the polygon into multiple polygons by these > multiple lines? Starting from PostGIS 2.5.0, you can split a polygon by a multiline with ST_Split. With an earlier version you'll have to split the polygon multiple times. https://postgis.net/docs/ST_Split.html -- Arnaud
