[postgis-users] Split polygon by line
Birgit Laggner birgit.laggner at thuenen.de
Thu Oct 18 07:47:37 PDT 2018
I believe QGIS can not deal with GeometryCollections which are the resulting geometrytype of ST_Split.
Your idea is not bad, but why do you save the result as wkt?
I would try:
SELECT (ST_Dump(ST_Split(circle, line))).geom::geometry (polygon,0) As geom
INTO layerq
FROM (SELECT
ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(190, 190)) As line,
ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) As circle) As foo;
If you cast the geometry type like that (::geometry (polygon,0)), PostGIS should be able to populate the geometry_columns table automaticly.
Regards,
Birgit
Von: "Shane Carey" <careyshan at gmail.com>
An: "arnaud listes" <arnaud.listes at codata.eu>
CC: postgis-users at lists.osgeo.org
Gesendet: Donnerstag, 18. Oktober 2018 18:55:44
Betreff: Re: [postgis-users] Split polygon by line
Ok thanks, will do in future:
This is what I have tried and no joy- any ideas? Thanks in advance.
SELECT ST_AsText((ST_Dump(ST_Split(circle, line))).geom) As wkt
INTO layerq
FROM (SELECT
select populate_geometry_columns();
Le gach dea ghui,
Shane Carey
GIS and Data Solutions Consultant
On Thu, Oct 18, 2018 at 3:38 PM Arnaud L. < [ mailto:arnaud.listes at codata.eu | arnaud.listes at codata.eu ] > wrote:
Le 18/10/2018 à 18:43, Shane Carey a écrit :
> Yep, I run the following:
> SELECT ST_Split(circle, line)
> INTO qlayer
> FROM (SELECT
> But this layer does not show up as a gis layer in qgis?
Probably because the geometry_columns table is not populated.
Try to either create the destination table first and then to insert in
it, or maybe just run :
SELECT Populate_Geometry_Columns();
> Thanks in advance for your help. Sorry, what do you mean by top post?
[ https://en.wikipedia.org/wiki/Posting_style | https://en.wikipedia.org/wiki/Posting_style ]
Bottom or interleaved posting are the preferred style.
Arnaud
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181018/d8c5ad17/attachment.html>
