[postgis-users] Split polygon by line
Sandro Santilli
strk at kbt.io
Thu Oct 18 07:51:35 PDT 2018
On Thu, Oct 18, 2018 at 04:38:53PM +0200, Sandro Santilli wrote:
> I guess QGIS wants to know the exact geometry type of the layer,
> which you could specify with a cast:
> SELECT ST_Split(circle, line)::geometry(polygon)
Sorry, I was too quick at answering. ST_Split returns a
GEOMETRYCOLLECTION, not a polygon (split creates multiple polys)
so you want to ST_Dump them, for example:
SELECT geom FROM ST_Dump(
ST_Split(
ST_Buffer('POINT(0 0)'::geometry, 10),
'LINESTRING(-20 5, 20 5)'
--strk;
