[postgis-users] Fw: MakeLine into new layer
Brent Wood pcreso at yahoo.com
Mon Oct 22 12:30:23 PDT 2018
Off the top of my head...
That returns the longest straight line within a polygon.
I suggest your workflow is to create a target table first (with a column for the id of the polygon it came from), so you have somewhere to put the linestrings (not necessary, but I find it tidier).
eg:
create table long_lines (id integer primary key), geom  geometry(LINESTRING, <SRID>);
then run your query...
INSERT INTO long_linesSELECT id,
   ST_MakeLine(St_LongestLine(
    (SELECT geom FROM floodplainw
    WHERE id = 1),
    WHERE id = 1))
Cheers
Brent Wood
 To: postgis-users at lists.osgeo.org
 Sent: Tuesday, October 23, 2018 8:07 AM
 Subject: [postgis-users] MakeLine into new layer
Hi,I am trying to find the longest line of a polygon and insert it into a new line. I can create the makeline as in the code below but cannot create a new layer out of it using the INTO keyword. Any help would be appreciated. Thanks
SELECT
    WHERE id = 1),
    WHERE id = 1))
Le gach dea ghui,
Shane CareyGIS and Data Solutions Consultant
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181022/92bead3a/attachment.html>
