[postgis-users] Problem creating postgis (2.5) extension with postgres 11
Raúl Marín Rodríguez
rmrodriguez at carto.com
Mon Oct 29 06:08:15 PDT 2018
Can you check if you have PROJ installed? If you are using a package
manager it should have been installed a dependency.
On Mon, Oct 29, 2018 at 1:58 PM Richard Huesken
<richard.huesken at gmail.com> wrote:
> Hi,
> I'm having troubles creating a postgis extension in a postgres11 database (running on Oracle Enterprise Linux 7).
> As postgres user in the testgeo database I run:
> create extension postgis
> The error is:
> SQL Error [XX000]: ERROR: could not load library "/usr/pgsql-11/lib/postgis-2.5.so": /usr/pgsql-11/lib/postgis-2.5.so: undefined symbol: geod_polygon_init
> Can somebody please point out what I'm doing wrong ?
> Installed packages:
> [root at ol-pg11 Downloads]# yum list installed | grep postgresql11
> postgresql11.x86_64 11.0-1PGDG.rhel7 @pgdg11
> postgresql11-contrib.x86_64 11.0-1PGDG.rhel7 @pgdg11
> postgresql11-libs.x86_64 11.0-1PGDG.rhel7 @pgdg11
> postgresql11-plpython.x86_64 11.0-1PGDG.rhel7 @pgdg11
> postgresql11-server.x86_64 11.0-1PGDG.rhel7 @pgdg11
> [root at ol-pg11 Downloads]# yum list installed | grep postgis25
> postgis25_11.x86_64 2.5.0-1.rhel7.1 @pgdg11
> postgis25_11-client.x86_64 2.5.0-1.rhel7.1 @pgdg11
> [root at ol-pg11 Downloads]# uname -a
> Linux ol-pg11.rihu-ho 4.1.12-124.20.7.el7uek.x86_64 #2 SMP Wed Oct 24 14:15:06 PDT 2018 x86_64 x86_64 x86_64 GNU/Linux
> Thanks in advance,
> Richard.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
carto.com
