[postgis-users] PostGIS case usages
Gerry Creager - NOAA Affiliate gerry.creager at noaa.gov
Tue Oct 30 14:29:30 PDT 2018
Regina
I use PostGIS for weather station (surface observations) data, as well as
quality control flags. I'm now starting to look at weather satellite data
with the newer GOES-16 and -17 satellites (GOES-R and -S). Keeping with the
"all things meteorological" theme, I also have played, with limited
success, at zenith-pointing lidar datasets looking at the lowest layers of
the atmosphere for structural data but that set doesn't lend itself too
well to a spatial application because of the sparse nature of the sensors.
Finally, point-cloud to acquire weather radar volumes is another one under
development.
I suspect these aren't generic for what your editors and publisher were
looking for, but it's a start.
Thanks for undertaking a new book; I'm looking forward to it!
Gerry
On Fri, Oct 26, 2018 at 12:06 PM Regina Obe <lr at pcorp.us> wrote:
> Hey all.  So we've been in talks with our editor about having a 3rd Edition
> of PostGIS hopefully to be released around the same time as PostGIS 3.0.
> I think they are more or less sold on the idea except they did ask about
> current market share and usage.
> Part of the reason for that is our previous editions focused a lot on  "How
> do I use this function or do this weird sounding thing that only GIS people
> can make sense of"  instead of "How do I do this real world thing"
> So one of the thoughts was having our table of contents be more like "How
> do
> I do this with PostGIS" in somewhat laymen terms that most people can
> relate
> to - like Political Districting, Real Estate analysis (walk scores,
> elevation measurements to determine viablility of building on a plot of
> land)
>  without scaring people off with "real world things" they can't relate to
> or
> in overly techy terms.
> Also since the 2nd Edition (which was in 2015 super ancient now since the
> New shiny version at the time was 2.1 and 2.1 is not even supported
> anymore).
> Other major thing changed is a lot of people are deploying PostGIS on cloud
> offerings like Amazon RDS, Microsoft Azure, and Google PostgreSQL for Cloud
> so we plan to cover a bit about some things relevant in those that may not
> be relevant when deploying on your own server.
> That said, if people can respond with what things they are currently using
> PostGIS for and also what hosting they are using for PostGIS, that would be
> helpful for us to get a better idea of focus points.
> It'd be great if you posted on the list, but if you are shy or need your
> usage anonymized, you can write directly to me.
> Thanks,
> Regina
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Gerry Creager
NSSL/CIMMS
405.325.6371
“Big whorls have little whorls,
That feed on their velocity;
And little whorls have lesser whorls,
And so on to viscosity.”
Lewis Fry Richardson (1881-1953)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181030/2187dfb2/attachment.html>
