[postgis-users] GEOSUnaryUnion: TopologyException: found non-noded intersection BUT geom is valid
Darafei "Komяpa" Praliaskouski me at komzpa.net
Tue Sep 18 17:46:42 PDT 2018
This is not supposed to happen.
Can you please isolate the offending rows unioning them pairwise and file
them as a ticket? Here's a handy helper function that returns True if Union
failed:
create or replace function st_union_fails(geom1 geometry, geom2 geometry)
    returns boolean
as $$
begin
    begin
        geom1 = ST_Union(Geom1, geom2);
        return false;
        exception when others
        then
            return true;
    end;
end;
language plpgsql;
вт, 18 сент. 2018 г. в 16:25, Birgit Laggner <birgit.laggner at thuenen.de>:
> Dear discussion group,
> I am trying to ST_Union several polygons and get a TopologyException
> (GEOSUnaryUnion: TopologyException: found non-noded intersection  between
> LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) and
> LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) at
> 3564420.7944701263 5426786.9800475985).
> I have tested with ST_Valid and all polygons in the datasets are valid.
> The dataset is pretty large (53.5 Mio. polygons) and will probably get
> grouped into around 8.7 Mio resulting geometries during ST_Union.
> If I try to ST_Union the geometries near the point ST_Union mentions in
> the error message (ST_Buffer with up to 100 metres), everything works fine.
> I am out of ideas how to find the problematic geometry or at least how to
> work around the TopologyException.
> My PostGIS version is: "POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1
> r4246" SFCGAL="1.2.2" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL
> 1.11.3, released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" TOPOLOGY
> RASTER"
> I would be very glad if anyone would come up with ideas how to solve my
> problem.
> Thanks a lot in advance!
> Regards,
> Birgit
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180919/55810cb0/attachment.html>
