[postgis-users] GEOSUnaryUnion: TopologyException: found non-noded intersection BUT geom is valid
Birgit Laggner
birgit.laggner at thuenen.de
Wed Sep 19 02:52:09 PDT 2018
Dear Darafei,
in preparation of filing the ticket, I tested the ST_Union on my selected, supposedly problematic geometries. Interestingly, the ST_Union worked without a problem on my small selection table. I aborted the ticket creation because I can't file this as a reproducible bug.
My (then unnecessarily complicated workaround) of course worked fine, too. That means, I am able to get my work done, unfortunately, I still don't know what the original problem was.
I am willing to let it rest and mark it as mysterious behaviour of a large dataset, as long as nobody has a specific interest to go to the bottom of the problem?
Thanks a lot again for the idea with the wrapper to extract to problematic rows.
Kind regards,
Birgit
Von: "Birgit Laggner" <birgit.laggner at thuenen.de>
An: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Gesendet: Mittwoch, 19. September 2018 09:47:41
Betreff: Re: [postgis-users] GEOSUnaryUnion: TopologyException: found non-noded intersection BUT geom is valid
Dear Darafei,
good idea to write a wrapper to ferret out the offending rows. I had to change it a bit because I don't use ST_Union(geometry, geometry) but the aggregate ST_Union(geometry). Since I am not very experienced in writing aggregates, I modified the wrapper that it fits for ST_Union(geometry[]) and used it in my query with ST_Union_Fails(array_agg(geom)).
I have found 3 groups with a total of 923 geometries which returned an error with ST_Union.
As soon as I get access to my old userID, I will file the them as a ticket.
In the meantime I will try to union the problematic geometries in a loop one at a time with st_makevalid after each loop - maybe that will work as a workaround, now I could reduce the number of geometries dramatically.
Thank you very much for your help!
Kind regards,
Birgit
Von: "Darafei \"Komяpa\" Praliaskouski" <me at komzpa.net>
Gesendet: Mittwoch, 19. September 2018 02:46:42
This is not supposed to happen.
Can you please isolate the offending rows unioning them pairwise and file them as a ticket? Here's a handy helper function that returns True if Union failed:
create or replace function st_union_fails (geom1 geometry , geom2 geometry )
returns boolean
as $$
begin
begin
geom1 = ST_Union (Geom1 , geom2) ;
return false ;
exception when others
then
return true ;
end ;
end ;
language plpgsql ;
вт, 18 сент. 2018 г. в 16:25, Birgit Laggner < [ mailto:birgit.laggner at thuenen.de | birgit.laggner at thuenen.de ] >:
Dear discussion group,
I am trying to ST_Union several polygons and get a TopologyException (GEOSUnaryUnion: TopologyException: found non-noded intersection between LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) and LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) at 3564420.7944701263 5426786.9800475985).
I have tested with ST_Valid and all polygons in the datasets are valid.
The dataset is pretty large (53.5 Mio. polygons) and will probably get grouped into around 8.7 Mio resulting geometries during ST_Union.
If I try to ST_Union the geometries near the point ST_Union mentions in the error message (ST_Buffer with up to 100 metres), everything works fine. I am out of ideas how to find the problematic geometry or at least how to work around the TopologyException.
My PostGIS version is: "POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" SFCGAL="1.2.2" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" TOPOLOGY RASTER"
I would be very glad if anyone would come up with ideas how to solve my problem.
Thanks a lot in advance!
Regards,
Birgit
postgis-users mailing list
[ mailto:postgis-users at lists.osgeo.org | postgis-users at lists.osgeo.org ]
[ https://lists.osgeo.org/mailman/listinfo/postgis-users | https://lists.osgeo.org/mailman/listinfo/postgis-users ]
Darafei Praliaskouski
Support me: [ http://patreon.com/komzpa | http://patreon.com/komzpa ]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180919/b43f44b3/attachment.html>
