[postgis-users] GEOSUnaryUnion: TopologyException: found non-noded intersection BUT geom is valid
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Wed Sep 19 02:56:08 PDT 2018
923 is still pretty much to review. I hope this snipped can help you
isolate just a really breaking couple, run it in a loop while it still
deletes something:
delete
from bad_input
where ctid = (
select ctid
from bad_input a
where (
select st_union_fails(array_agg(geom)) from
bad_input b where a.ctid != b.ctid
limit 1
ср, 19 сент. 2018 г. в 10:47, Birgit Laggner <birgit.laggner at thuenen.de>:
> Dear Darafei,
> good idea to write a wrapper to ferret out the offending rows. I had to
> change it a bit because I don't use ST_Union(geometry, geometry) but the
> aggregate ST_Union(geometry). Since I am not very experienced in writing
> aggregates, I modified the wrapper that it fits for ST_Union(geometry[])
> and used it in my query with ST_Union_Fails(array_agg(geom)).
> I have found 3 groups with a total of 923 geometries which returned an
> error with ST_Union.
> As soon as I get access to my old userID, I will file the them as a ticket.
> In the meantime I will try to union the problematic geometries in a loop
> one at a time with st_makevalid after each loop - maybe that will work as a
> workaround, now I could reduce the number of geometries dramatically.
> Thank you very much for your help!
> Kind regards,
> Birgit
> *Von: *"Darafei \"Komяpa\" Praliaskouski" <me at komzpa.net>
> *An: *"PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
> *Gesendet: *Mittwoch, 19. September 2018 02:46:42
> *Betreff: *Re: [postgis-users] GEOSUnaryUnion: TopologyException: found
> Hi,
> This is not supposed to happen.
> Can you please isolate the offending rows unioning them pairwise and file
> them as a ticket? Here's a handy helper function that returns True if Union
> failed:
> create or replace function st_union_fails(geom1 geometry, geom2 geometry)
> returns boolean
> as $$
> begin
> begin
> geom1 = ST_Union(Geom1, geom2);
> return false;
> exception when others
> then
> return true;
> end;
> end;
> language plpgsql;
> вт, 18 сент. 2018 г. в 16:25, Birgit Laggner <birgit.laggner at thuenen.de>:
>> Dear discussion group,
>> I am trying to ST_Union several polygons and get a TopologyException
>> (GEOSUnaryUnion: TopologyException: found non-noded intersection between
>> LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) and
>> LINESTRING (3.56442e+06 5.42679e+06, 3.56442e+06 5.42679e+06) at
>> 3564420.7944701263 5426786.9800475985).
>> I have tested with ST_Valid and all polygons in the datasets are valid.
>> The dataset is pretty large (53.5 Mio. polygons) and will probably get
>> grouped into around 8.7 Mio resulting geometries during ST_Union.
>> If I try to ST_Union the geometries near the point ST_Union mentions in
>> the error message (ST_Buffer with up to 100 metres), everything works fine.
>> I am out of ideas how to find the problematic geometry or at least how to
>> work around the TopologyException.
>> My PostGIS version is: "POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1
>> r4246" SFCGAL="1.2.2" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL
>> 1.11.3, released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" TOPOLOGY
>> RASTER"
>> I would be very glad if anyone would come up with ideas how to solve my
>> problem.
>> Thanks a lot in advance!
>> Regards,
>> Birgit
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180919/39d16151/attachment.html>
